Relay 109 (m): Replacement for New Car
Post02-04-2004, 20:59    Subject: Relay 109 (m): Replacement for New Car Quote
Hello.
While exploring my car, I also opened up the ubiquitous 109.
What I saw there immediately made me reach for my soldering iron...
 File size:  367.41 KB
 Viewed:  8283 times
Translated on 29-09-2026, 12:16.
Post02-04-2004, 21:44    Subject: Relay 109 (m): Troubleshooting for New Cars Quote
ulf wrote:
What I saw there immediately made me turn on my soldering iron.
These crimp connections are extremely temperature-stable, while solder joints are always the worst solution.
I am familiar with stress tests for these connections, and it's quite remarkable what they can withstand without any issues. For comparison, these connections were soldered and subjected to the same tests.
The soldered connections failed after only a few temperature cycles (-40°C to +85°C) under vibration stress, while the clamped connection remained intact.
The reason for these inspections is that during servicing, these crimp connections were re-soldered, and in various vehicles, these re-soldered connections have come loose.
Translated on 29-09-2026, 12:18.
Sir Tortsch
Post03-04-2004, 0:27    Subject: Relay 109 (m): Troubleshooting New Car Issues Quote
Hello.
What I saw there immediately made my soldering iron heat up.
@ulf, but with you, nothing has a chance to remain untouched icon_biggrin.gif.
The reason for these investigations was that during the service, these crimp connections were re-soldered, and in various vehicles, these re-soldered connections have come loose.
[irony]
'Something like that definitely doesn't happen with ULF; everything is disassembled after every trip.'
[/ironie]
[irony]
Translated on 29-09-2026, 12:20.
Post03-04-2004, 7:44    Subject: Relay 109 (m): Troubleshooting New Car Issues Quote
Bertil wrote:
... that during the service, these crimp connections were resoldered, and that in various vehicles, these resoldered connections have come loose.
Hi Bertil,
That's quite something... so, does the "solid" clamping connection fail if it's encased in solder?
Then I will shorten the connector wire slightly and bridge the gap to the contact pin with a loop made of very thin wire, which will absorb temperature and vibration stresses due to its elasticity.
Translated on 29-09-2026, 12:21.
Uwe
Post03-04-2004, 9:30    Subject: Relay 109 (m): Replacement for New Car Quote
... and put a spare 109 bulb next to the spare light bulbs in the glove compartment icon_eek.gif.
Uwe
Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
Translated on 29-09-2026, 12:22.
Post03-04-2004, 12:50    Subject: Relay 109 (m): Troubleshooting New Car Issues Quote
Hi Ulf,
Then I will simply shorten the connector wire a bit and bridge the gap to the contact pin with a loop made of very thin wire, which will absorb temperature and vibration stresses due to its elasticity.
Okay, the solder joint isn't great, but I'd leave it as it is for now. Just keep in mind that if your car ever malfunctions, it might be due to the solder joint. It will probably take several years for the solder joint to completely fail.
These crimp connectors look incredibly fragile, but they are not. You shouldn't repeatedly play with them (opening and closing them), as that's not good for these connections.
In particular, these clamping connections are ideal for applications where connections are exposed to significant temperature and vibration stress, such as in automobiles.
Translated on 29-09-2026, 12:23.
Post03-04-2004, 13:50    Subject: Relay 109 (m): Replacement for New Car Quote
Hello Bertil & all,
Let's take a slight detour into the realm of "development":
Why aren't semiconductor switches used instead of these complex relays?
The 109, with its only 3 connections, practically begs to be replaced, for example, by a transistor, just like the old Lima contact regulators, which have long since become obsolete.
A PNP Darlington switching transistor would be a great alternative to the 109: Connect the emitter to a constant positive voltage, the collector to the load (EDC), and the base to the motor computer's control output via a current-limiting resistor.
If the power transistor is properly saturated, the voltage drop across the switch is less than 0.1 volts, which results in minimal power dissipation.
Are there already FETs or other semiconductor switches available that can switch the load current without any voltage drop?
Something like that would be ideal for a fake AGR signal of the mass airflow sensor icon_wink.gif.
My engine seems to produce significantly less carbon buildup in the intake manifold compared to the AFN (the ASZ only produces a very light, dry carbon deposit), so I haven't yet made any firm plans to completely disable the EGR system. After almost 2,000 kilometers, I'm still holding off.
But you never know...
Translated on 29-09-2026, 12:26.
Post03-04-2004, 14:05    Subject: Relay 109 (m): Replacement for New Car Quote
ulf wrote:
Why aren't semiconductor switches used instead of these complex relays, which have been around for a long time?
I can't tell you that either. Perhaps the semiconductor switches in this power class are still 1 cent too expensive... icon_rolleyes.gif
Translated on 29-09-2026, 12:28.
No new posts Engine and instruments fail - Relay 109? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P068A Error: Engine Won't Start (Relay J271) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts Relay 109 for Audi A4 (1996): Location? Diesel Engine Technology
No new posts Relay 109 Diesel Engine Technology
No new posts Relais 109: Location for 1Z? Diesel Engine Technology
No new posts Relay Switch: Troubleshooting from 40 km/h Diesel Engine Technology
