Preheat LED On? Troubleshooting Engine Warm Start.
carstenAFN
Post02-04-2004, 22:32    Subject: Preheat LED On? Troubleshooting Engine Warm Start. Quote
I suppose it's not normal for the LED to briefly light up even when the engine is warm, right? I certainly don't experience that with older diesel engines. What could be causing this? The preheating time varies depending on the engine temperature, but the LED always comes on when the engine "starts."
The temperature sensor shows normal or plausible values when checked with VAGCOM. Is there any other meaningful check that can be performed?
(Maybe there's a clue about my cold start problem here...)
Greetings.
Carsten (AFN engine from Passat 35i, manufactured in March 1997).
Translated on 18-09-2026, 9:35.
Post03-04-2004, 7:38    Subject: Preheating LED on even with warm engine? Quote
Hi Carsten,
Yes, it's normal for the TDI. It's probably a warning light or something like that.
Translated on 18-09-2026, 9:36.
Jan6K
Avatar-Jan6K
Post03-04-2004, 8:34    Subject: Preheat LED On? Troubleshooting Engine Warm Start. Quote
The LED for the pre-glow function is currently not positioned parallel to the candles, but is controlled separately. This allows the main system (MSG) to use it for error messages and also as an indicator for the self-test. However, this only works if the LED is functioning correctly, as Ulf mentioned, so it will be tested.
The brief flash indicates that everything is okay, and it informs the engine computer about the power flow, ensuring that the LED itself is also functioning correctly.
If you want to monitor the glow plug function, simply (like Ulf, me, and probably others) connect an LED with a resistor in parallel to the glow plugs or the preheating relay.
Jan.
1Z5 CFHF / AHB H4D
Translated on 18-09-2026, 9:38.
carstenAFN
Post03-04-2004, 14:15    Subject: SEO: Best Practices for Website Optimization Quote
Thank you for the information; it's always reassuring when something is "normal" icon_smile.gif.
Greetings.
Carsten.
Translated on 18-09-2026, 9:39.
No new posts MKB ABC: Engine Start Issues After MSG Replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J, ESP Control indicator is lit up. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J ABS Light: Repair Guide & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1K: Why is the Golf VI called that? Transmission, Chassis, Body & Interior
No new posts Is the 96 kW PD engine still experiencing issues in the M... Diesel Engine Technology
No new posts Glow plug problem Audi A4 TDI On-Board Diagnostics (OBD)
No new posts TDI: Blinking Glow Plug, Hard Starting Diesel Engine Technology
