Longer Gear for VW Golf 2 GTD?
Schnittlauch
Post05-04-2004, 17:09    Subject: Longer Gear for VW Golf 2 GTD? Quote
Does anyone know of a gearbox that is longer than the original one for a Golf2 GTD (71 hp, intercooler from a Sprinter, 0.9 bar boost)?
My Golf is misbehaving when running at full throttle above 5000 RPM, and I want to fix that!
I also did some research, but I couldn't find anything. I only found models with cable pulls, but I don't want to modify anything.
Thank you. Best regards, Christian.
Translated on 07-10-2026, 19:54.
Uli S.
Post06-04-2004, 9:34    Subject: Longer Gearbox for VW Golf 2 GTD? Quote
The 4T transmission (e.g., in the 2er GTD), to my knowledge, is the longest in the 020 series. If you consistently drive with 0.9 bar of boost and have the ESP properly adjusted, you're close to the limit of what that transmission can handle, around 190 Nm. I destroyed mine with 1.2 bar, and that's why, along with the gearing, I installed a CYP from a 110PS TDI. Most of it is plug-and-play, but you will need a few parts. If you're interested in details, check out this http://forum.piranha-net.de/; it's a forum for the older models without electronics. This forum here is more about the high-tech issues and how to deal with them.
Best regards, Uli.
Golf2 GTD AAZ, LLK, CYP
Bus T3 JX
2x Golf2 GTD/SB
97er Golf 3 AFN, 70-100% Pöl
97er Golf 3 Variant AFN
96er Passat 35i AFN
Translated on 07-10-2026, 19:55.
Schnittlauch
Post06-04-2004, 10:58    Subject: Longer Gear for VW Golf 2 GTD? Quote
Okay, I'll take a look. I hope my transmission holds up, because I'm planning to install an AAZ turbocharger with 1.1 bar of boost soon!
Translated on 07-10-2026, 19:56.
No new posts Golf 1J: Gearbox Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Manual transmission, Difficult to shift gears Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document LT 28, Transmission Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Longer Gearbox for TDI 110 HP ASV Engine Diesel Engine Technology
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Golf II TD transmission Diesel Engine Technology
No new posts Golf 4 1.9 TDI with ERX transmission Transmission, Chassis, Body & Interior
