Slider potentiometer changeover
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
wolfi_b
Post12-04-2004, 20:03    Subject: Slider potentiometer changeover Quote
Hello.
While I was driving on the highway today, my Audi B4 TDI 1Z, manufactured in July 1992, started to jerk intermittently. After hitting a large bump, the control lamp on the engine control unit also came on. Reading the error memory resulted in the error code "00541 Potentiometer for slider position (G99); 27-10- implausible signal - intermittent."
To the best of my knowledge, that's the feedback from the actual injection amount. Or is it?? My repair manual only says "have it replaced ". Can't I do that myself?? I've already done quite a bit myself (like replacing the head gasket, etc.), but I don't really want to disassemble the fuel injection pump. However, I haven't checked the plugs and wires yet.
Is the replacement difficult, and what is the cost of a new donor? Or can I not do it myself?
Thank you very much, Wolfi.
Translated on 04-07-2026, 18:56.
Post13-04-2004, 15:22    Subject: Slider potentiometer changeover Quote
Regarding the "successor" device, the HDK sensor in the quantity setting unit, I know that not even all VW or BOSCH workshops are able to handle it, and very few actually do.
Most of the time, the entire pump is replaced.
But first, check the plugs and cables, maybe there's just a loose connection.
Translated on 04-07-2026, 18:58.
No new posts Serpentine belt (drive belt) replacement for T6 TDI with ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacement of injector nozzles/holders on a VP-TDI Troubleshooting & Guides
No new posts ATF (Automatic Transmission Fluid) replacement in the aut... Troubleshooting & Guides
No new posts Change of the ZKD Diesel Engine Technology
No new posts ZR change in PDs? Diesel Engine Technology
No new posts ZR - Change at 1.4 PD Diesel Engine Technology
No new posts ZMS Wechsel ASZ mit ERF Transmission, Chassis, Body & Interior
