VAG-COM Error: Coolant Temperature Sensor (G2)
Marzocchi
Post22-04-2004, 17:55    Subject: VAG-COM Error: Coolant Temperature Sensor (G2) Quote
Hello, I recently got VAG-COM, and I have a Golf IV ALH with 90 horsepower.
Did this error occur?
In the A4 car, VDO V18 instrument cluster.
Coding 05142
Shop ID: WSC 46639
1 fault found.
01039 Coolant Temperature Sensor G2
30-10: Open or short circuit to B+. Intermittent.
What does that tell me?
Thank you. Best regards, Bernd.
Golf IV - ALH - Erstzulassung 9/99
Karma: +807 / -0   Thank you, like it!
Post22-04-2004, 19:10    Subject: VAG-COM Error: Coolant Temperature Sensor (G2) Quote
http://dict.leo.org
The cable/connector to the coolant temperature sensor is broken (or, of course, the temperature sensor itself).
The error occurs sporadically (intermittently).
PowerSound3L
Post23-04-2004, 6:15    Subject: VAG-COM Error: Coolant Temperature Sensor (G2) Quote
hello,
Okay, let me just say this.
it's the temperature sensor, or the dual-temperature sensor itself.
apparently, there were quality issues with these.
There were definitely about 10% failure rates with the Lupo 3Ls.
The original one lasted almost exactly 2 years and showed the same error.
greetings
WarLord
Post23-04-2004, 9:52    Subject: VAG-COM Error: Coolant Temperature Sensor (G2) Quote
'My Passat has the exact same problem. It's going to the workshop now, and hopefully, it will get a new one (I still have warranty, so that's covered). Our company's Golf also had this issue; the display would also always show a '-' and disconnect (just like my Passat).' The component that supplies fuel to the engine is fine.
Best regards, WarLord.
Marzocchi
Post23-04-2004, 10:24    Subject: Thank you for the many answers Quote
Well, if that part is broken, shouldn't my water temperature gauge also be acting up? But it's working normally. It slowly rises up to 90 degrees and then stays there. VAG om also indicates good values for the water temperature.
What should I do? I think I'll just delete the error and see what happens... or what?
Bernd
PowerSound3L
Post23-04-2004, 10:59    Subject: VAG-COM Error: Coolant Temperature Sensor (G2) Quote
hi,
It's probably just brief interruptions.
You can especially see this with the Lupo 3L, as the undertemperature indicator (the blue light that illuminates when the temperature is below 14°C) only flashes briefly and then turns off.
greetings
WarLord
Post23-04-2004, 14:10    Subject: VAG-COM Error: Coolant Temperature Sensor (G2) Quote
@PowerSound3L
Um, hello, I just wanted to confirm that I agree with your opinion. I probably should have also mentioned that I've already located the problem thanks to the Passat 3B forum, and I've now asked the workshop to replace the faulty part.
PowerSound3L
Post23-04-2004, 16:30    Subject: VAG-COM Error: Coolant Temperature Sensor (G2) Quote
@PowerSound3L
Um, hello, ...
I accidentally clicked on 'quote' instead of 'edit' because I actually wanted to edit something.
greetings
WarLord
Post24-04-2004, 11:21    Subject: VAG-COM Error: Coolant Temperature Sensor (G2) Quote
Oh, I see.
@Marzocchi
Okay, so I had to implement some logging for different operating states. In my case, the sensor sometimes fails, and then it displays a water temperature of 30 degrees Celsius. That would likely happen to me as well, even with a cold engine.
No new posts P246E - Exhaust Gas Temperature Sensor (EGS) Bank 1 Sensor 4 General Tips
No new posts Intake Air Temp Sensor P0110: Causes & Fixes General Tips
No new posts P0341 - Camshaft Position Sensor (G40): Implausible Signal Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Distance Control Sensor Fault: Causes & Fixes Electrical Systems, Vehicle Electronics, Multimedia
No new posts Differential pressure sensor: Error code P2453 despite ne... Diesel Engine Technology
No new posts Air Quality Sensor Replacement: Golf 7 Error Persists Electrical Systems, Vehicle Electronics, Multimedia
No new posts AGR Disconnect: Engine Coolant Temp. Error 00522 Diesel Engine Technology
