Remove Brake Caliper: Guide & Instructions
wbuchi82
Karma: +9 / -0   Thank you, like it!
Post28-04-2004, 11:00    Subject: Remove Brake Caliper: Guide & Instructions Quote
"Now that it's time to replace my front brake pads, I wanted to ask if I need a special Allen key for the job. Yesterday, I replaced the pads and rotors on the rear axle without any problems. But none of my Allen keys fit on the front. What's needed for this? I own an Audi A3, year 1999."
Thank you for your help.
Translated on 07-10-2026, 22:15.
Back to top Profile PM Email
christians
Post28-04-2004, 11:41    Subject: Remove Brake Caliper: Guide & Instructions Quote
"In the past, I had SW7 brake calipers, which were included in the T40 repair kit. However, the Audi 100 calipers are quite similar."
Gruß Christian
Translated on 07-10-2026, 22:16.
ekolaus
Post28-04-2004, 16:50    Subject: Remove Brake Caliper: Guide & Instructions Quote
It used to be SW7 for me, in the T40 repair kit. However, it's for an Audi 100, but the calipers are quite similar. }
If it's a Teves saddle (recognizable by the wire spring on the lever), then...
It's a 7mm socket Allen key.
Translated on 07-10-2026, 22:17.
wbuchi82
Post30-04-2004, 6:34    Subject: Remove Brake Caliper: Guide & Instructions Quote
Hello guys!
Thank you for the answers. I managed to fix it now. It was a 7mm Allen key. I'd like to know why car manufacturers always come up with such great obstacles. Sooner or later, we'll get all the screws off anyway! icon_lol.gif
"MFG" is an abbreviation for "mit freundlichen Grüßen," which means "with kind regards" or "best regards" in English.
Translated on 07-10-2026, 22:18.
Post30-04-2004, 7:59    Subject: Remove Brake Caliper: Guide & Instructions Quote
What's so special about a 7mm Allen wrench?
My first Golf Diesel (year 1977) already had a size 7 Allen key needed to hold the shock absorber rod in place. Also, my 1979 Jetta has several size 7 Allen key screws.
Just because the "Superbillig" brand socket set sold at the hardware store doesn't include a 7mm socket doesn't mean that a 7mm socket doesn't exist.
Translated on 07-10-2026, 22:19.
Jürgen
Post30-04-2004, 15:22    Subject: Remove Brake Caliper: Guide & Instructions Quote
The 7mm Allen key was already used in the original Golf 1100 engine for...
Valve adjustment is necessary - it's a perfectly normal tool!
Translated on 07-10-2026, 22:20.
No new posts Document Golf 1J1587, Transmission Console Mounting Not R... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Overhaul front brake caliper Transmission, Chassis, Body & Interior
No new posts Rear brake caliper, sequence Transmission, Chassis, Body & Interior
No new posts Brake Pads Too Big for Girling 54 Calipers Transmission, Chassis, Body & Interior
No new posts Rear Brake Caliper: Sticking Handbrake Mechanism Transmission, Chassis, Body & Interior
