TDI 1.9: Find Mechanic for Inspection
Go to page: 1, 2  Next
tdi racer
Post21-04-2004, 19:40    Subject: TDI 1.9: Find Mechanic for Inspection Quote
'I'm looking for someone in the Stuttgart area who might be able to take a look at my Audi 1.9 TDI B4. I'm having a problem, but I'm not sure what needs to be replaced. I've heard it could be the fuel injection pump, the knock sensor, etc. Before I spend a lot of money (on a fuel injection pump), I want to be sure what the actual problem is. In my opinion, even Audi workshops don't really know what they're talking about!'
Please provide the text you would like me to translate from German to English. I'm ready to help!
Matthias.
Translated on 30-10-2026, 16:15.
Julian
Post21-04-2004, 19:41    Subject: TDI 1.9: Find Mechanic for Inspection Quote
Car, engine, etc.?
Problem...?
Translated on 30-10-2026, 16:16.
Marco
Post21-04-2004, 21:04    Subject: TDI 1.9: Find Mechanic for Inspection Quote
Hi Matthias,
I recall that Rainer K. once offered a similar service, so why don't you just contact him about it?
Translated on 30-10-2026, 16:17.
Karma: +807 / -0   Thank you, like it!
Post21-04-2004, 21:27    Subject: TDI 1.9: Find Mechanic for Inspection Quote
Unfortunately, Stuttgart is a bit far away... However, the service has not proven to be satisfactory.
So far, all we've heard is talk, and people are looking for a solution via email or phone.
Obviously, people would rather pay for the x-th unnecessary parts replacement... icon_rolleyes.gif
Marco
Post21-04-2004, 21:33    Subject: TDI 1.9: Find Mechanic for Inspection Quote
Greetings, Rainer
I don't recall you offering a 'crystal ball' diagnosis service. Unfortunately, that's a sad reality, and in the end, many people still didn't learn anything from it.
Translated on 30-10-2026, 16:18.
tdi racer
Post21-04-2004, 21:39    Subject: TDI 1.9: Find Mechanic for Inspection Quote
@Julian,
It's a 1994 Audi B4, 1.9 TDI engine, 1Z model.
The problem is that it has the infamous 'judder,' and from what I've gathered, you don't necessarily have to replace the entire ESP unit. When it's cold, it runs like a tractor from the pre-war era!
Unfortunately, this is my first diesel car, so I can't really say much about it.
P.S. I just meant that I would go to someone and they would look at my car. I thought that was clear! Of course, it wouldn't be bad if someone came to me, but that's too much to ask.
P.S.S. Great people here, respect. I didn't expect such quick responses!
Translated on 30-10-2026, 16:19.
palmstrollo
Post21-04-2004, 21:48    Subject: TDI 1.9: Find Mechanic for Inspection Quote
Hi tdi racer.
Regarding stuttering:
If it's the surging issue, you can perform a relatively simple test. Disconnect the connector from the speed sensor on the transmission (driver's side, below the fuel tank; there are two connectors there. The upper one is for the reverse lights, so disconnect the lower one). If the surging disappears after that, it's very likely that the metering unit is sticking --> replace the pump or continue experiencing the surging.
Regarding cold start performance:
This is an early-generation TDI. Don't expect overly smooth running. Mine also makes a lot of noise and wakes up the neighborhood when I start it in the morning when it's cold. Once it warms up, it gets better.
For troubleshooting:
An investigation using diagnostic software (such as VAG-COM) can also help to identify some of the faulty components.
Otherwise, try using the search function; you'll be overwhelmed with results...
Hermann.
Translated on 30-10-2026, 16:21.
thomas.diem
Post22-04-2004, 8:13    Subject: TDI 1.9: Find Mechanic for Inspection Quote
How does the shaking feel? Is it occasional or does it happen constantly?
Has the needle lift adjuster ever been replaced, or has a knock test been performed?
It's a common problem with the 1Z model!
Best regards, TD.
Translated on 30-10-2026, 16:23.
knubbi
Post22-04-2004, 15:46    Subject: TDI 1.9: Find Mechanic for Inspection Quote
... I live near Stuttgart (in Vaihingen/Enz). Is the distance acceptable for you?
I need more information about the vehicle first.
Hi Knubbi,
Post22-04-2004, 19:23    Subject: TDI 1.9: Find Mechanic for Inspection Quote
How about a workshop directory here on the forum, where workshops can register themselves?
Here's the procedure:
- Customer searches for a workshop near their location and receives a customer ID from the forum software when selecting one.
- The workshop repairs the car and emails me the customer ID and the vehicle registration number.
- Customer with ID fills out a web feedback form, and the submitted customer ID is compared to the customer ID from the workshop.
- Update workshop rating statistics.
In my opinion, this would prevent workshops from cheating, because any inconsistencies in feedback related to IDs would be noticeable.
Customers who try to sabotage a business, for example, by leaving negative reviews from a competitor, could only do so once, as they would be identifiable through their ID and vehicle registration plate information provided in the workshop feedback.
What do you think about it?
Translated on 30-10-2026, 16:25.
mersente
Post22-04-2004, 19:30    Subject: TDI 1.9: Find Mechanic for Inspection Quote
@Rainer: That sounds really good, damn it. icon_wink.gif
Translated on 30-10-2026, 16:26.
Sir Tortsch
Post22-04-2004, 22:07    Subject: TDI 1.9: Find Mechanic for Inspection Quote
Wow, great idea!!! (Then it will really only be about going to the friendly [place/business]!)
But what if I pick up my car and then realize, later at home, that something was done incorrectly? Can I submit the feedback form later, or edit it?
joergs
Post23-04-2004, 6:43    Subject: TDI 1.9: Find Mechanic for Inspection Quote
'Good idea! This could potentially lead to a more accurate and unbiased picture of the quality and performance of the workshops.'
Translated on 30-10-2026, 16:27.
tdi racer
Post23-04-2004, 8:54    Subject: TDI 1.9: Find Mechanic for Inspection Quote
@thomas.diem
'So, when the engine is cold, the misfiring is quite severe. It stops when the engine is under full load, and when I'm driving uphill, for example, it experiences a 'drop' around 3000 RPM, meaning it stops pulling. Even when I floor the accelerator, it becomes weaker and slower. As far as I know, the needle valve has not been replaced, nor has the knock sensor.'
Matthias.
Translated on 30-10-2026, 16:28.
haehnlein
Post25-04-2004, 12:07    Subject: TDI 1.9: Find Mechanic for Inspection Quote
tdi racer wrote:
For example, when I'm driving uphill, it experiences a "drop in power" at around 3000 RPM, meaning it stops pulling, and even if I give it full throttle, it becomes weaker and slower.
Hi Matthias,
You can probably solve this problem yourself (costing approximately 2-5 euros in materials). Take a look at the hoses for the turbocharger pressure regulation (especially near the magnetic valve that limits boost pressure). You will most likely find a hose that has come loose -> remove it and the problem should be solved. Several Audi 80 drivers, including myself, have experienced this issue.
Please always specify the mileage icon_exclaim.gif. You can and should change the NHG (noise, vibration, harshness) component after more than 150,000 km. That other jerking sounds very much like a quantity control valve icon_sad.gif. Is it particularly bad when driving at low RPM? Also, check the search function for "crankshaft bolt".
____________
Kein Auto mehr!
Translated on 30-10-2026, 16:29.
WarLord
Post25-04-2004, 12:50    Subject: TDI 1.9: Find Mechanic for Inspection Quote
Well, every engine will probably stutter when driven at too low an RPM. You probably meant low RPM.
Best regards, WarLord.
Translated on 30-10-2026, 16:30.
No new posts Looking for frame number Transmission, Chassis, Body & Interior
No new posts Labeldata for 038 906 019 CG Diesel Engine Technology
No new posts Audi A6 4F CAN IDs: Find them here! On-Board Diagnostics (OBD)
No new posts Diagnostic Expert Hamburg: Find the Best! On-Board Diagnostics (OBD)
