v8monster Guest
24-05-2004, 7:59 Subject: 2. K-line at the connector |
Hello everyone.
'If I can't find a serial transceiver (STG) connected to pin 7 (even with different baud rates), could I temporarily connect the CAN High line to pin 15 instead? Shouldn't that be the second CAN line?' Is it possible to use Kline with vehicles that don't have a CAN bus? Or could I damage something?
Basti.
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
24-05-2004, 9:08 Subject: 2. K-line at the connector |
No, you can try that. What kind of car are we talking about?
Profile PM WWW Garage |
v8monster Guest
24-05-2004, 12:01 Subject: 2. K-line at the connector |
Hello Rainer,
A6 MJ 2002 2.5 TDI
Theresias Guest
25-05-2004, 2:19 Subject: 2. K-line at the connector |
In the A6 (4B) model, the second K-line was installed starting in week 18 of 2001, which means, as you correctly noted, that some control units are only present in those models.
By simply 'reconfiguring' things, you should be able to achieve your goal. However, I would recommend a long-term solution with an interface that has 2 K-lines, as this works better, especially with auto-scans, and will ultimately save you time and effort.
v8monster Guest
25-05-2004, 13:24 Subject: 2. K-line at the connector |
I just built the new one (expanded and adjustable, or whatever it's called), and I don't want to build another one so soon. I wasn't sure about the one with the 2 'klines'; it was only mentioned as a discussion point or for testers.
Is there an interface available with 2 Klein connectors and an Lline connector? I actually have a C4 100 myself, and it still has the L-line.
PrivatBereich Guest
25-05-2004, 13:27 Subject: 2. K-line at the connector |
Is there an interface with 2 Klines and Lline as well?
Sure, at Rainer's shop, it's called KKL ... http://shop.dieselschrauber.de/index.php/cPath/21{MARKER}
v8monster Guest
25-05-2004, 14:42 Subject: 2. K-line at the connector |
And what about building it yourself?
Theresias Guest
25-05-2004, 14:45 Subject: 2. K-line at the connector |
v8monster Guest
25-05-2004, 14:49 Subject: 2. K-line at the connector |
Thank you  .
