VAG COM and Audi A6 V6 TDI, Model Year 2000
knubbi
Post26-05-2004, 5:20    Subject: VAG COM and Audi A6 V6 TDI, Model Year 2000 Quote
Hello!
I've been using my diagnostic cable with VAG Com on my Audi A6 V6 TDI, model year 2000, for quite some time now.
It works fine so far, but I simply can't access the ABS or automatic transmission control module. Often, the error message appears that VAG COM cannot set the baud rate, and sometimes (for the ABS), it simply says that it cannot find the control module. During the connection process, however, the instrument panel beeps and flashes wildly, and a brake warning light appears in the FIS (multifunction display).
Can anyone tell me what can be done there? Do I need a different cable?
Knubbi.
P.S.: I have a USB-to-Serial adapter.
knubbi
Post26-05-2004, 14:47    Subject: VAG COM and Audi A6 V6 TDI, Model Year 2000 Quote
...I answered my own question.
So, that's settled then.
PrivatBereich
Post26-05-2004, 14:59    Subject: VAG COM and Audi A6 V6 TDI, Model Year 2000 Quote
It would be really great if you could share your solution to the problem with us. Was war die Ursache: die Startbaudrate, der USB-Adapter, oder ein ungewöhnlicher Fehler?
Private.
knubbi
Post26-05-2004, 15:46    Subject: VAG COM and Audi A6 V6 TDI, Model Year 2000 Quote
...I thought, if no one responds, it probably isn't that interesting.
But... it was the USB adapter.
PrivatBereich
Post26-05-2004, 16:14    Subject: VAG COM and Audi A6 V6 TDI, Model Year 2000 Quote
Thank you for the feedback!
No new posts Audi A4: Blower Malfunction - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3 8L from 18/2000 onwards, whistling sounds fro... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Carlife Plus: Worth it for A6 2000 1.9 TDI? Transmission, Chassis, Body & Interior
No new posts Audi A6: Kombi Tail Light Conversion (2000-2002) Diesel Engine Technology
No new posts OBD2 Scanner for VW Passat 2000 PD Diesel Engine Technology
No new posts AFN Engine Torque Dip at 2000 RPM Diesel Engine Technology
