A6 2.5 TDI Engine Exploded View Diagram and Front Disassembly
HateMondays
Post26-05-2004, 21:52    Subject: A6 2.5 TDI Engine Exploded View Diagram and Front Disassembly Quote
Hello, does anyone know how to remove the front cover on an A6? I have something oily and attached behind the timing belt. Unfortunately, after removing the timing belt cover, I can't clearly see what it is or what I can do there. I assume that you need to remove the front cover to access it.
Thank you in advance for your icon_idea.gif.
Translated on 17-07-2026, 19:54.
Gladbecker
Post27-05-2004, 6:21    Subject: Subject: Re: Audi A6 2.5 TDI Engine Exploded Diagram and Front End Disassembly Instructions Quote
Hello!
Please provide the text you would like me to translate from German to English. I will then give you only the translation, without any explanations.
http://www.elcats.ru
Have fun!
Hello, does anyone know how to remove the front cover on an A6? I have something oily and attached behind the timing belt. Unfortunately, after removing the timing belt cover, I can't clearly see what it is, nor can I do anything there. I assume that you need to remove the front cover to access it.
Translated on 17-07-2026, 19:56.
Rudi
Post27-05-2004, 8:00    Subject: A6 2.5 TDI Engine Exploded View Diagram and Front Disassembly Quote
If your Cyrillic isn't displaying correctly, try the following link (everything needs to fit on one line):
http://www.translate.ru/url/tran_url.asp?lang=ru&url=http%3A%2F%2Fwww.elcats.ru%2F&direction=rg&template=General&cp1=NO&cp2=NO&autotranslate=on&transliterate=on
Best regards, Rudi.
Translated on 17-07-2026, 19:57.
HateMondays
Post27-05-2004, 9:00    Subject: What you find these days... Quote
with translation, the page is actually usable...
Thank you for the tip icon_lol.gif icon_lol.gif icon_lol.gif icon_wink.gif.
Now I just need to figure out how to get everything sorted out in the front.
No new posts Audi A6: Door Sill Removal Guide Transmission, Chassis, Body & Interior
No new posts Disassembling ZMS: A Step-by-Step Guide Transmission, Chassis, Body & Interior
No new posts Rear bumper removal Audi A6 4F sedan Transmission, Chassis, Body & Interior
No new posts Passat 1.9 TDI Visco Coupling/Power Steering Pump Removal Transmission, Chassis, Body & Interior
