22-05-2004, 18:09 Subject: LDA Content: Forum Share at 4‰? |
So far, 7 installation photos of LDAs have been featured in the article , viewed by over 1,800 forum members - this represents a calculated percentage of approximately ~4 parts per thousand of the local TDIs that are equipped with LDAs  .
Man, I'm really disappointed... are you all (almost) waiting for a serious problem to occur before taking action, and then relying on workshops or VAGCOM, or do you simply have no interest in monitoring the boost pressure while driving?
Or are the rest of the LDA drivers just too lazy to take 1 or 2 photos and send them to me - or do you not have a digital camera or a phone with a camera yet?  Gruß Ulf
Translated on 01-08-2026, 3:59.
Profile PM Garage |
Julian Guest
22-05-2004, 18:34 Subject: LDA Content: Forum Share at 4‰? |
Hmm, it's more convenient and, above all, more accurate to use a laptop when there are actual problems.
'Furthermore, there aren't really any visually appealing solutions available, except for the tachometer backlight offered by HGP.'
http://hgp-turbo.de/images/vw/fahrt.jpg
In my opinion, something more important would be an oil thermostat, which I will also retrofit in my vehicle.
Translated on 01-08-2026, 4:01.
SeatArosa1.7SDI Guest
22-05-2004, 18:35 Subject: LDA Content: Forum Share at 4‰? |
I would like to, but my boost pressure is always 1 bar (absolute) = atmospheric pressure. Therefore, an LDA (Lambda-Sonde) would be quite boring  .
Translated on 01-08-2026, 4:02.
Gremlin Guest
22-05-2004, 21:14 Subject: LDA Content: Forum Share at 4‰? |
Julian addresses it:
There is no aesthetically pleasing built-in solution available. I would actually quite like a display with a flickering pointer.
Where should we build?
CU Gremlin.
x world one Blaumann
22-05-2004, 22:02 Subject: LDA Content: Forum Share at 4‰? |
"Oh, the LDA is already installed. I just cut myself while using that stupid hole saw. But I can take a picture of the installation, which looks a bit unsightly at the moment because of the mishap." VW Golf III TDI Avenue, MKB 1Z, EZ96
Spritmonitor
Translated on 01-08-2026, 4:03.
ThomasB Guest
22-05-2004, 22:32 Subject: LDA Content: Forum Share at 4‰? |
Double-sided printing  :
(Image moved to the technical article / Best regards, Ulf)
Thomas
23-05-2004, 10:07 Subject: LDA Content: Forum Share at 4‰? |
Gremlin wrote: | there is no aesthetically pleasing built-in solution. I would actually like such a wiggling pointer...
just where to build? |
Hi Ralf,
Among other things, I have designated this collection for that purpose.
Even if an Octavia doesn't appear in it (at first), you might be able to adapt a mounting idea from another model and apply it to your car  .
@ Thomas B:
I have moved your image to the relevant section of the article.
A few additional words regarding the pressure connection and electrical connection would certainly be helpful for those interested in replicating it  .
@x-world one:
Quote: | | I just cut myself while using the stupid jigsaw. But I can take a picture of the installation, which is currently still quite unsightly, because of it. |
You can easily manipulate digital photos to make it seem like nothing happened (if you're feeling ashamed).  Gruß Ulf
Translated on 01-08-2026, 4:05.
Profile PM Garage |
23-05-2004, 16:42 Subject: LDA Content: Forum Share at 4‰? |
Okay, slightly edited:
The placement isn't exactly ideal. I had the LDA temporarily mounted in the storage compartment of the center console, but even then, it's hard to see. So it doesn't matter whether I have to look to the right or left; visibility is poor either way. VW Golf III TDI Avenue, MKB 1Z, EZ96
Spritmonitor
Translated on 01-08-2026, 4:07.
23-05-2004, 18:21 Subject: LDA Content: Forum Share at 4‰? |
x world one wrote: | Okay, slightly edited:
The installation location is certainly not ideal. I had only temporarily attached the LDA to the storage compartment in the center console, but even then, it's hard to see. So, it doesn't matter whether I have to look to the right or left below. |
See? It works! *lol*
And the photo collection is growing.
I'm going to "borrow" that photo from your post again. Gruß Ulf
Translated on 01-08-2026, 4:08.
Profile PM Garage |
DocSnydor Guest
24-05-2004, 7:22 Subject: LDA Content: Forum Share at 4‰? |
'I'm in a similar situation to 'x world one'... I also messed up the installation a bit, but I've been using it for over 2 years now and haven't felt like making it look better...'
@Ulf: I'll still send you a picture this week, though...
Translated on 01-08-2026, 4:09.
Stukov Guest
28-05-2004, 17:32 Subject: LDA Content: Forum Share at 4‰? |
I'm probably a bit too late with my image; I just saw that there's already a similar image in the research article.
Regarding the placement, it should be noted that some plastic trim needs to be cut away to install it. If you have seat heating and/or climate control, the controls and temperature sensor will also obstruct the area.
(Image deleted, it can now be admired in the photo collection  / Ulf).
Translated on 01-08-2026, 4:10.
29-05-2004, 7:48 Subject: LDA Content: Forum Share at 4‰? |
Stukov wrote: | I think my image might be a bit too late to the game; I just saw that there's already a similar image in a published article.  |
No problem, it will still go into the collection  . Gruß Ulf
Translated on 01-08-2026, 4:11.
Profile PM Garage |
garth.brooks Guest
04-06-2004, 9:59 Subject: LDA Image: My Photo Gallery |
Hi Ulf,
Here's my solution. I needed a quick fix and wanted to be able to easily remove it later. So, it was just a temporary measure that has now been in place for a year.
As you can see from the disassembled seat heater control unit, I'm also having a problem with that.
(Image deleted -> can be viewed in the technical article / Ulf)
Translated on 01-08-2026, 4:12.
04-06-2004, 14:58 Subject: LDA Image: My Photo |
garth.brooks wrote: | | As you can see from the disassembled seat heater controller, I'm also having a problem with that... |
Hi Garth,
As long as comfort-related defects don't effectively disable the entire vehicle (e.g., power windows that no longer close), things are still relatively lenient...
My motto, "everything you don't really need to drive with stays outside, so you don't waste unnecessary money and avoid trouble," is constantly being confirmed, including by your problem.
I will delete your image here once it's included in the collection. Gruß Ulf
Translated on 01-08-2026, 4:13.
Profile PM Garage |
WarLord Guest
04-06-2004, 23:06 Subject: LDA Content: Forum Share at 4‰? |
'The Egg grill is really great in the winter. But it's time for an upgrade, and a built-in heater would be nice. The downside is that you also end up using it for leisurely drives in the summer.'
Best regards, WarLord.
Translated on 01-08-2026, 4:14.
Gremlin Guest
05-06-2004, 18:27 Subject: LDA Content: Forum Share at 4‰? |
The standing heater can be used in the summer for ventilation (standby ventilation function). This helps to remove the most intense heat before you arrive.
'Cu Gremlin'
Translated on 01-08-2026, 4:15.
