It's hard to get started
Thomas100
Post09-06-2004, 8:23    Subject: It's hard to get started Quote
Hello forum!!!
'Since last week, I've been having a problem with the gears (1-5) in my TDI 110PS car. They are very difficult and jerky to engage. When I push the gear knob forward or backward, I feel resistance. It takes a lot of force to get the gear to engage. There are no loud noises or clunking sounds.' The entire process is not speed-dependent, and it doesn't always happen.
A badger chewed through a pair of coolant hoses, and I replaced them. One of the hoses was the one that runs from the engine into the passenger compartment. I disconnected it directly at the engine, and some coolant spilled onto the transmission. Later, I realized that the cover for the clutch was missing, so I can't rule out the possibility that some coolant may have gotten into it. But the clutch isn't slipping.
I've just lubricated all the mechanical components on the gearbox. It has achieved a little bit, but it's still far from being good.
Does anyone have any idea what else it could be?
Thank you in advance.
Thomas.
No new posts Golf 5 Gearbox: Won't Shift Gears While Driving Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine and instruments fail - Relay 109? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A2 8Z0044 AMF, Difficult to shift reverse gear Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Extend Hallways? Tips & Ideas. Diesel Engine Technology
No new posts Lupo 3L: No Gears / Troubleshooting Transmission, Chassis, Body & Interior
No new posts Loss of Power in High Gears On-Board Diagnostics (OBD)
No new posts Accessing Car ECUs: How-To Guide On-Board Diagnostics (OBD)
