2.5 TDI: Grinding Noise at 1400 RPM
Delfin
Post09-06-2004, 16:23    Subject: 2.5 TDI: Grinding Noise at 1400 RPM Quote
Hello everyone!
I have the 2.5 TDI (BFC) engine with 120 kW / 163 hp.
multitronic (GEC) transmission. It is still a...
The EU3 variant, manufactured in 2002. The car has 25,000 km on the odometer.
'On routes with inclines and declines (e.g., uphill and downhill sections)...'
(During mountain driving), it occurs at an engine speed of 1400 RPM.
Okay, so, when applying the maximum torque of 310 Nm,
often manifests as a 'grinding' or 'grating' noise.
At lower and higher speeds, or when driving on a flat surface,
It is not possible to hear this sound. It is not...
to avoid the turbine-like whistling of the turbocharger, but rather about...
A sound that somehow sounds metallic and unhealthy.
Does anyone know what component this might be?
Does this possibly indicate that it will soon fail?
Thank you.
Dolphin.
Translated on 01-09-2026, 2:25.
uhrmeister
Post15-06-2004, 19:04    Subject: Grinding Noise: Causes and Solutions Quote
I'm experiencing the same problem. It's a Passat TDI, 96 kW AVF engine, manufactured in 2001, automatic transmission, with 150,000 km on the odometer.
A faint grinding noise (possibly from the front right?) when under load.
It disappears immediately when you take it off the gas.
I would appreciate any tips.
Bernhard.
Translated on 01-09-2026, 2:27.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post15-06-2004, 19:11    Subject: 2.5 TDI: Grinding Noise at 1400 RPM Quote
Always these guessing games based on sounds.
I would be concerned if it wasn't working properly, because then the turbo would be broken. icon_biggrin.gif
If the turbine wheel is actually rubbing against the housing, you're probably going to have the turbocharger fly off and hit you in the head soon.
You definitely mean a "pssssssssss" or a "pfffffffffffffff", right? icon_twisted.gif
and that is normal.
B.Eng (FH) u. KFZ Meister
Translated on 01-09-2026, 2:28.
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance deficiency, piercing noise, nuclear... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K, from KW26/97, Loud Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climate compressor makes a grinding noise Transmission, Chassis, Body & Interior
No new posts Squealing or grinding engine noise, Tiguan 2.0 TDI Diesel Engine Technology
No new posts Ladedruckdifferenz bei 1400 u/min mit u. ohne VTG-Betäti... Diesel Engine Technology
No new posts Common-Rail TDI with knocking noises between at 1400 RPM Diesel Engine Technology
