Service Reset/Disable Beep
RalfBru
Post15-07-2002, 14:39    Subject: Service Reset/Disable Beep Quote
can someone tell me how to reset the service interval indicator on a 1999 Passat TDI PD115 with the 'tech package'? Procedure according to The description in my handy little book seems to only apply to models without the Tech package...
Does anyone know how to disable the beeping from all the warning lights (fuel level, windshield washer, oil low, etc.)? 'A simple notification would be sufficient; the beeping sound is somehow annoying...'
Thank you and best regards.
Ralf
ttns4
Post21-08-2002, 8:19    Subject: Service Reset/Disable Beep Quote
Hello Ralf,
I also have a Passat AJM, manufactured in 1999 (2000 model year).
85KW PD.
The beeping is also annoying me, and unfortunately, it seems like it can't be turned off.
But resetting works perfectly according to the instructions, I've done it several times before, I don't currently have the exact sequence in mind, but as far as I remember, the pen must be at the display of the instrument panel when the !! is switched off. Turn the ignition on.
...it has been perfectly fine 3 or 4 times already...
'I'm more troubled by the performance issues and the excessive diesel consumption.'
Hoping you can understand this statement.
Thorsten
P.S.: If you have any questions about the type, just email me. It might take a while, but I'm also happy if someone who drives the same model can answer. (By the way: Our Passat also has the same technology package!)
No new posts Audi RS 6: Resetting Automatic Transmission Learning Values Electrical Systems, Vehicle Electronics, Multimedia
No new posts Reset WIV: Incorrect Infotainment Values On-Board Diagnostics (OBD)
No new posts Skoda Octavia: Reset Oil Service Light On-Board Diagnostics (OBD)
No new posts Reset Service Indicator Light Diesel Engine Technology
