AFN Performance Issues: Troubleshooting & Fixes
volker24
Post15-01-2005, 6:40    Subject: AFN Performance Issues: Troubleshooting & Fixes Quote
I'm having a problem with my Toledo AFN. When driving, there's a slight jerk, and the car continues to run normally until I try to accelerate, at which point it loses power. After restarting the engine, the power is restored. The problem isn't constant; it's occurred 4 times in the last 4 months. After the first occurrence, the workshop replaced the mass airflow sensor (MAF), and everything was fine for about a month, but it happened twice yesterday. I've read in forums that it might be a limp mode issue, but I'm not sure what's triggering it. I can't read any diagnostic data because I don't have the necessary equipment. I'm not expecting a definitive diagnosis, but I would appreciate any tips so I can be somewhat prepared when I take it to the workshop.
Thanks in advance,
Volker
Translated on 27-08-2026, 11:39.
Varianti
Post15-01-2005, 19:08    Subject: AFN Performance Issues: Troubleshooting & Fixes Quote
'I once had a similar issue. I was messing around with something and forgot to reconnect the vacuum line to the control unit during reassembly. This resulted in the exact effect you described: the emergency mode would engage under increasing load. Everything was fine in gears 1-4 with full throttle, but starting at 120 km/h in 5th gear, the emergency mode would kick in.'
Perhaps one of the rubber seals is pushed in or porous. I would check that first.
Translated on 27-08-2026, 11:40.
No new posts Sudden performance loss after restart, then okay again Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts August 1, 2011 - Nationwide launch of digital radio DAB+ Electrical Systems, Vehicle Electronics, Multimedia
No new posts after timing belt replacement, AUY performance loss Diesel Engine Technology
No new posts ZR Seal Replacement: Performance Loss Troubleshooting On-Board Diagnostics (OBD)
No new posts Leistungsverlust nach A3 belieben... Diesel Engine Technology
