28-07-2004, 9:53 Subject: ALE Nozzles: Size, Pressure, and Specs |
Hi.
To the best of my knowledge, the ALE is the Euro3-1Z/AHU model.
The two older ones have 184 my / 190 bar Dueses.
What does the ALE have?
The background is that I have an MSA12 (021AF) in the 1Z, and now I have a MAS15 here (021HD - only used in the ALE).
If the ALE 220 bar nozzles are used, the injection start timing will be different (thanks, Rudi), and it likely won't be compatible with my old 190 bar nozzles.
m; Transparency, Teamwork
Translated on 07-09-2026, 17:18.
Profile PM Garage |
Rudi Guest
28-07-2004, 11:02 Subject: ALE Nozzles: Size, Pressure, and Specs |
Hi Martin,
It's possible that you misunderstood me there.
It will work with your nozzles! These are the 'spray start' nozzles.
I already sent that to you. They're not that different.
The dynamic injection start may need to be adjusted.
(which was not necessary after my conversion to .216 / 220 bar).
Best regards, Rudi.
Translated on 07-09-2026, 17:20.
