VAG-COM communication problem with Audi 2.5 TDI (4B)
Klausel
Post09-07-2004, 13:19    Subject: VAG-COM communication problem with Audi 2.5 TDI (4B) Quote
Hello!
Today, at the request of the technician, I connected my VAG-COM (large connector) to an Audi A6 2.5 TDI (4B), manufactured around 1996, using a Bosch service center. My VAG-COM is relatively new.
In the Auto-Scan menu (which reads all error codes), the system requires you to enter the chassis type. We selected "4B," and then several errors appeared, but none related to the engine, even though (according to the mechanic) there are "definitely" some stored there.
were.
When we tried to directly access the "Engine" section from the "Select" menu (where you can also read error codes), the connection failed.
(genauen Fehlertext weiss ich nicht mehr, endete mit "Retry ? "Yes / No").
"This menu doesn't ask for the chassis type - how does VAG-COM know?"
there, with whom he has to deal.
"Sorry, I didn't thoroughly use the search function; the craftsman was from..."
He's very impressed with the VAG-COM and wants to buy it, provided this issue can be resolved.
It's possible, so it would be interesting to solve the problem.
Greetings,
Klaus.
Translated on 18-07-2026, 13:53.
Post09-07-2004, 17:29    Subject: VAG-COM communication problem with Audi 2.5 TDI (4B) Quote
Which adapter version? The hobby version with the KKL interface or the HEX-USB?
Translated on 18-07-2026, 13:55.
Klausel
Post09-07-2004, 21:50    Subject: VAG-COM communication problem with Audi 2.5 TDI (4B) Quote
Hello!
This is what's listed in my customer account:
"Products"
1 x Complete diagnostic adapter kit (RS232), €189.00.
My computer still has serial ports.
Greetings,
Klaus.
Translated on 18-07-2026, 13:56.
Post10-07-2004, 9:59    Subject: VAG-COM communication problem with Audi 2.5 TDI (4B) Quote
Hello Klaus,
Since the KL version doesn't have a switch yet, you can rule out an incorrect switch position.
I'm not sure why the connection failed. Have you tried multiple times, and perhaps turned the ignition on and off in between, just in case the engine control unit got somehow corrupted?
For professional use in a workshop, a professional-grade system would naturally be the better choice.
What is the engine code letter?
Translated on 18-07-2026, 13:57.
Klausel
Post10-07-2004, 12:21    Subject: VAG-COM communication problem with Audi 2.5 TDI (4B) Quote
Hello Rainer!
We have executed the process I described earlier exactly twice.
where we turned off the ignition after the first time (and then turned it on again icon_smile.gif). The results were identical.
As soon as I have more detailed engine specifications, I'll get back to you.
Greetings,
Klaus.
Translated on 18-07-2026, 13:58.
No new posts Problem: Electronic Parking Brake (S-Tronic) in Audi A4, ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B7: 2.5 TDI Issue Above 2500 RPM Diesel Engine Technology
No new posts Differences in MSG for Audi 2.5 TDI AAT engines On-Board Diagnostics (OBD)
No new posts Audi 100 2.5 TDI: Adaptation Channels? On-Board Diagnostics (OBD)
No new posts Audi A6 C4: Crankshaft Pulley Bolts Diesel Engine Technology
