turbocharger oil leak and whistling at 1800 RPM
happy
Post30-08-2004, 20:58    Subject: turbocharger oil leak and whistling at 1800 RPM Quote
I have a Golf IV 1.9 TDI with 150 horsepower. During the oil change, it was noticed that there was a slight oil leak coming from the turbocharger. The average oil consumption is approximately 1 liter per 15,000 kilometers.
In addition, there is a hissing sound at 1,800 RPM, which is not excessively loud, but can be heard clearly when the window is open.
Can someone give me a tip?
Thank you in advance.
Karma: +782 / -0   Thank you, like it!
Post30-08-2004, 21:21    Subject: turbocharger oil leak and whistling at 1800 RPM Quote
Either the intercooler pipe or hose is cracked, or the connections of the pipes are leaking. O-rings in the connectors (haven't disassembled any yet)?
happy
Post30-08-2004, 21:26    Subject: turbocharger oil leak and whistling at 1800 RPM Quote
Thank you.
As far as I know, no one else has tried that before.
No new posts Passat 3C 2.0 BKP Weiss-/Blaurauch bei 1800 1/min, Ruckeln Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts turbolader und Leistung Diesel Engine Technology
No new posts AFN mit 1Z Steuergerät und turbolader, ist das möglich Diesel Engine Technology
No new posts turbolader der 4. - audi a6 2.5tdi quattro Diesel Engine Technology
No new posts ladedrucksensor und turbolader anlernen, polo 6c gti Gasoline Engine Technology
