Injection pump for Astra or Vectra DTi...
chrisklose
Post25-07-2004, 18:54    Subject: Injection pump for Astra or Vectra DTi... Quote
'Has anyone had experience with the fuel injection pump of a DTi Astra or Vectra? The engine simply cuts out during acceleration, and then it stays off. There are no error codes in the diagnostic system. I disassembled the pump, and I only found normal wear on the pre-injection control valve. The feed pump, piston, etc., all seem to be okay.'
What I suspect now is the fuel injection quantity regulator, which is located at the outlet of the high-pressure side. Does anyone have any reference points, such as resistance values or testing methods, for that?
chris
Translated on 14-07-2026, 21:19.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts Astra G Einspritzpumpe Einspritzzeitpunkt Fehlercode 0149 Diesel Engine Technology
No new posts Fuel Injector: Repair or Replace for 2.5 TDI? Diesel Engine Technology
No new posts Opel Vectra BJ 2006 Diesel Partikelfilter Probleme Diesel Engine Technology
No new posts Astra 2006: Read VC Unit Data On-Board Diagnostics (OBD)
