Hesitant starting with blue smoke on AAZ engine
zivi
Post23-07-2004, 9:25    Subject: Hesitant starting with blue smoke on AAZ engine Quote
Hello!!!
I'm having a problem with my AAZ! icon_confused.gif I have to glow the engine at least 3 times for it to start properly, otherwise it only runs on 2 cylinders, and the other 2 cylinders come on later! And all of this is accompanied by blue smoke. I was told that this could be due to the BOSCH glow plugs! Has anyone perhaps already gained experience with that icon_question.gif?
The engine is probably not the problem; it only has 30,000 km on it. The pump is also likely not the issue!
Marco
Post23-07-2004, 9:30    Subject: Hesitant starting with blue smoke on AAZ engine Translating...
[Translating...]Moin,
An die Glühkerzen glaube ich bei den heutigen Temperaturen noch nicht so recht
hast Du denn schon mal in der Rubrik Fachartikel vorbei geschaut?
Oder einfach mal nach Deinem Problem gesucht? In den Fachartikeln ist Haarklein beschrieben wie Du die Glühkerzen prüfen kannst.
Hier der Link: https://community.dieselschrauber.org/en/viewtopic.php?t=3094
zivi
Post23-07-2004, 9:41    Subject: Hesitant starting with blue smoke on AAZ engine Quote
I've already checked the spark plugs; they actually work! I've also checked the compression, and that's okay too! The fuel injectors are also fine! It starts well when it's warm outside, but only has problems when it's cold. I'm completely stumped; I can't think of anything else it could be! I was just told to try replacing the spark plugs with NGK ones, and I'd like to get a second opinion before I do that.
Marco
Post23-07-2004, 9:44    Subject: Hesitant starting with blue smoke on AAZ engine Quote
I have already checked the candles, and they actually work!
how actually?
Does it function, including the controls?
If you remove the candles and then check something, that's only half the truth.
You didn't actually check the entire control system for the candles.
zivi
Post23-07-2004, 9:58    Subject: Hesitant starting with blue smoke on AAZ engine Quote
I can take another look! Maybe I'll find something after all!
Post23-07-2004, 10:06    Subject: Hesitant starting with blue smoke on AAZ engine Quote
zivi wrote:
I can take another look! Maybe I'll find something after all!!
If the terminals of the electrodes are exposed (with a nut), simply connect a voltmeter to each electrode while it is glowing.
Around 10V should be present everywhere.
Post23-07-2004, 10:43    Subject: Re: Hesitant starting with blue smoke on AAZ engine Quote
Why do I immediately think of the crankshaft bolt when I see the AAZ icon_wink.gif? Can someone explain that to me ?
/viewtopic.php?t=3313&highlight=crankshaft bolt
/viewtopic.php?t=2564&highlight=crankshaft bolt
I am sorry, I cannot access external websites, including the one you provided. Therefore, I am unable to translate the text from the given URL.
zivi
Post23-07-2004, 19:07    Subject: Hesitant starting with blue smoke on AAZ engine Quote
When I installed the new engine, I used the stronger bolt. Additionally, it has a TDI crankshaft with the half-moon alignment, which provides more security against twisting.
magga
Post07-08-2004, 20:03    Subject: Hesitant starting with blue smoke on AAZ engine Quote
Hello everyone,
Last week, I was really stumped by the same starting problems with my Ibiza (230,000 km). The engine wouldn't start in the morning, when the temperature was around 20 degrees Celsius (in the garage), and it would only start after about 2 seconds. The next night, I left it outside, which was 10 degrees colder. The following morning, I had to crank it for about 10 seconds before the engine reached 950 RPM. Otherwise, when it was warm, it ran as usual.
While troubleshooting, I came across your posts. So, I turned the engine back on and, using a flashlight, shone it on the 'tower' of the three pulleys. I could already see an imbalance of about 3 mm. So, I turned the engine off and had it towed to my trusted mechanic. He was almost able to unscrew the crankshaft screw by hand. The crankshaft already showed clear signs of the loose screw. Strangely enough, a 12.9 grade bolt was installed, but it was still loose. But what's the point, it will be discovered eventually.
The end face of the shaft was re-milled by hand using a specialized tool, and a new timing pulley with belt and tensioner was installed. Along with some other minor repairs, the total cost was 450 euros. I think it's an unnecessary expense, but it's better than a forced free runner.
Bertil, thank you very much for your advice regarding KWS.
Markus.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil consumption in 2.0 TSI engines: A break-in issue? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Thick blue smoke on startup Diesel Engine Technology
No new posts White smoke from AC when starting car Transmission, Chassis, Body & Interior
No new posts A6 2.5 TDI BAU will nicht anspringen Diesel Engine Technology
No new posts BMW 325 tds; Starts poorly when the engine is warm + Weak... Diesel Engine Technology
