Gearbox Damage VW Golf 3 TDI Variant
owi
Post20-04-2002, 11:43    Subject: Gearbox Damage VW Golf 3 TDI Variant Quote
'Whenever I start driving, the first gear always pops out. The transmission doesn't make any noises, and if I hold the gear in place, everything is normal. I'm 100% sure the problem lies with the transmission. The car has driven 101,000 kilometers (according to the odometer). Has anyone else experienced this issue?'
Translated on 25-07-2026, 5:19.
tim27
Post20-04-2002, 19:37    Subject: Rings: Meaning, Types & History Explained Quote
'Those might be the synchronizer rings that cause your gear shifts to slip; they're probably just wearing out a bit prematurely. Have you checked the oil level?'
Translated on 25-07-2026, 5:20.
Varianti
Post22-04-2002, 14:03    Subject: Gearbox Damage VW Golf 3 TDI Variant Quote
Try adjusting the settings again first. Maybe it's just misaligned.
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Golf3 pulls to the left (SOLVED) General Tips
No new posts Tankklappenentriegelung failure Golf 5 Variant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 3 TDI: Stuttering/Misfiring When Idle Diesel Engine Technology
No new posts Golf V TDI: 66kW Engine Specs & Performance Diesel Engine Technology
No new posts Boost Curve for ALH 66kW Engine Diesel Engine Technology
No new posts Gearbox Failure on ERF Trucks Transmission, Chassis, Body & Interior
