Adjust settings
ckone
Post24-08-2004, 19:35    Subject: Adjust settings Quote
I wanted to adjust or check my circuit settings today.
Now I've encountered a problem because I don't know what function lever A is supposed to have.
[img][/img]
Should it lock the shift shaft when pressed, or what is its function?
It's very easy for me, and not much is really happening.
Sure, here's the translation:
'Thank you in advance.'http://home.arcor.de/chris_kern/teil.JPG{MARKER}
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post24-08-2004, 19:52    Subject: Adjust settings Quote
Yes, exactly, the circuit is locked in place with this 90-degree adjuster.
To do this, you need to press the part downwards as described, but not all the way.
Sometimes, there's a rumbling sound somewhere between the bottom and the top.
Unfortunately, it often breaks if you put too much force on it.
B.Eng (FH) u. KFZ Meister
ckone
Post24-08-2004, 20:15    Subject: Adjust settings Quote
Thanks, I managed to do it, although for some reason I had to push it in and then turn it.
This topic is locked, you cannot edit or reply. Third gear shifting/synchronization (resolved) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Clutch engagement point and gear shift adjustment for Vol... On-Board Diagnostics (OBD)
No new posts VAG Wiring Harness: Ulf's Guide On-Board Diagnostics (OBD)
No new posts 2.4GHz Circuit Clone: Layout and Design On-Board Diagnostics (OBD)
No new posts Very convoluted circuit Diesel Engine Technology
