Jetta TD Wheel Bearing Replacement (JR Engine)
euro
Post07-09-2004, 20:50    Subject: Jetta TD Wheel Bearing Replacement (JR Engine) Quote
Hello everyone,
Has anyone ever replaced the Pleuel (connecting rod) and crankshaft bearings of a 1.6TD engine while it was still installed in the vehicle?
Is that even possible?
I'm having problems with the oil pressure, and everything I've been able to find out so far suggests that the bearing shells are likely worn out.
Hendrik.
Translated on 27-10-2026, 16:03.
DerBruzzler
Post07-09-2004, 21:58    Subject: Jetta TD Wheel Bearing Replacement (JR Engine) Quote
Theoretically, it is possible to replace the connecting rod bearings and crankshaft bearings while the engine is still installed, but this doesn't make much sense because the transmission needs to be removed to get the crankshaft out, and at that point, the engine is almost out anyway! Besides, all the parts are more accessible then, and the timing belt needs to be removed anyway. So, it's better to just remove the entire engine!
Best regards, Daniel.
Translated on 27-10-2026, 16:04.
No new posts Passat 3BG AVB - Remove bearing from Visco fan Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Jetta GT Upload
No new posts Avatar Storage: Secure Cloud Backup Solution Upload
No new posts Carburetor flange for Jetta / Golf 1.3L, engine code: HK Gasoline Engine Technology
No new posts Jetta TD Oil Pressure: Troubleshooting & Solutions Diesel Engine Technology
