Turbocharger V6 TDI 180HP for 150HP + EGR Off
leonardo2005
Post04-09-2004, 14:45    Subject: Turbocharger V6 TDI 180HP for 150HP + EGR Off Quote
Hello.
a question,
I drive an Audi A6 with a 2.5L V6 TDI engine.
150 horsepower, AFB.
My mechanic installed a new turbocharger from a V6 TDI 180HP engine in my car, but he also sealed off the EGR pipes and made sure the intake manifold was airtight.
He said it would increase performance, is that true?
What does the engine do now without EGR?
The problem now is that my car consumes a lot of diesel, 10 liters per 100 kilometers icon_cry.gif.
Is this due to a deactivated EGR system or the turbocharger from the 180 hp engine?
'Thank you.'
bye
leo
Translated on 25-07-2026, 6:22.
Post04-09-2004, 15:14    Subject: Turbocharger V6 TDI 180HP for 150HP + EGR Off Quote
Please avoid posting the same content multiple times! I have deleted your second post.
Please refer to the "Deactivation of the AGR" article under "Technical Articles" for information about the AGR (Automatic Gearbox Restriction).
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It refers to a sudden and strong gust of wind.
Translated on 25-07-2026, 6:24.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post04-09-2004, 15:20    Subject: Turbocharger Upgrade for 150HP+ TDI Engines Quote
leonardo2005 wrote:
Hello.
"Thank you."
bye
leo
It only runs with fresh, clean air icon_lol.gif icon_lol.gif icon_lol.gif icon_lol.gif.
More power? No!
Improved responsiveness -- YES.
Higher fuel consumption: Possibly, yes, because in the partial load range, more air is drawn through the mass airflow sensor (MAF), which can result in more fuel being injected.
B.Eng (FH) u. KFZ Meister
Translated on 25-07-2026, 6:25.
mcgyver2k
Post05-09-2004, 10:42    Subject: Turbocharger Upgrade for 150HP+ TDI Engines Quote
Steffarn wrote:
leonardo2005 wrote:
Hello.
"Thank you."
bye
leo
More power? No!
Higher fuel consumption possibly YES, because in the partial load range, more air is drawn through the mass airflow sensor (MAF), and therefore more fuel can be injected.
The amount of fuel injected in the partial load range is only sufficient to produce the power requested by the driver. If more fuel were injected with the same pedal position, the car would accelerate faster, and the driver would automatically ease off the accelerator. I would rather say that fuel consumption slightly decreases because you don't have to press the pedal further all the time until the turbo kicks in.
@leonardo
Was only the turbocharger replaced, or were any changes made to the software as well? If the latter is true, then that's likely where the cause of the increased fuel consumption lies.
edit:
Did you buy the turbos in a pack of two, or did you throw one away?
01er Skoda Fabia Combi ATD
Translated on 25-07-2026, 6:28.
Manuel V
Post05-09-2004, 19:08    Subject: Turbocharger V6 TDI 180HP for 150HP + EGR Off Quote
As far as I know,
Is the front loader exactly the same for both the AFB 150 HP and the 180 HP models?
I believe there is only one spare part number for the 2.5L TDI engine.
Translated on 25-07-2026, 6:30.
WarLord
Post05-09-2004, 19:33    Subject: Turbocharger V6 TDI 180HP for 150HP + EGR Off Quote
The consumption will decrease because the efficiency increases when the EGR valve is closed.
Best regards, WarLord.
Translated on 25-07-2026, 6:31.
No new posts Turbocharger Repair 1.9 TDI ASZ Troubleshooting & Guides
No new posts Transporter 7D Turbocharger Pipes: ACV Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Sharan, Pfeifgeräusche vom Turbolader Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts New Website Design: Build Your Homepage Diesel Engine Technology
No new posts TDI 150PS: Power Loss Troubleshooting Diesel Engine Technology
No new posts Felgen Neue A3 Transmission, Chassis, Body & Interior
No new posts Ladedruckanzeige 150PS TDI Diesel Engine Technology
