Doku Touareg, Transmission in Emergency Mode (Solution)
Michael II
Post02-09-2004, 16:41    Subject: Doku Touareg, Transmission in Emergency Mode Quote
Check engine light is on, all gear display is showing red, transmission may be in emergency mode. Transmission Control Unit Error: "17225 / P0841 Sensor 1 for Hydraulic Pressure Transmission / Implausible Signal"
Cause:
Oil pressure switch on the transmission is broken.
Solution:
Read the entire vehicle's fault memory. If the error "17225 / P0841 Sensor 1 for Hydraulic Pressure Transmission / Implausible Signal" is present, the two oil pressure switches in the transmission must be replaced.
Parts required for the repair:
1 Seal (for oil pan) No.: 09D 321 371
1 Seal (for oil drain screw) Part number: 09D 321 181
1 O-Ring (for overflow opening) No.: 09D 321 379
1 ATF -No.: G 052 025 A2 10 Liter
2 Oil pressure switches, Part number: 09D 919 081
1 Oil tray (if damaged) No.: 09D 321 361
Tschüss
Michael II
Ratings - Doku Touareg, Transmission in Emergency Mode
No new posts Touareg documentation, clacking sounds coming from the st... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dacia/Renault Duster, squeaking noises steering column / ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: A4, Emergency Procedure After Strong Acceleration Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DSG transmission enters limp mode at oil temperatures abo... Gasoline Engine Technology
No new posts Automatic Transmission AFN: Oil Change, Gearbox. Diesel Engine Technology
No new posts Touareg R50 V10 Diesel Engine Technology
No new posts Touareg GRA.... On-Board Diagnostics (OBD)
