Pressure Transducer 1Z
x world one
Post06-09-2004, 12:42    Subject: Pressure Transducer 1Z Quote
Today, I checked all the pressure hoses in the engine compartment of my new car. I'm still wondering why the newer model is over 1 second slower in the benchmark test compared to the older one, and also much more sensitive to heat.
I discovered a valve on the thin hose that connects to the air filter housing. It's probably a pressure sensor, or something like that. The question is, did all 1Z models have this part? What does this part do? I'm pretty sure that the older 1Z models without air conditioning didn't have this part. I would remember that because it's positioned so awkwardly near the diesel filter housing in the new 1Z model that it makes it even harder to access.
Okay, hier ist die Übersetzung:
"I am grateful for explanations."
Spritmonitor
Post06-09-2004, 13:00    Subject: Pressure Transducer 1Z Quote
There are 2 valves on the 1Z that have "zero air" connections.
- The turbo control valve (N75) (officially called the "boost pressure control solenoid valve").
- The pressure sensor for the EGR system.
One draws air from the air filter, while the other draws air from the intake manifold to the turbocharger.
I think the pressure sensor on the Lufi is the one for the EGR system.
"Everyone has this 1Z part, that's for sure!"
Turbo valve: http://people.freenet.de/golf-schrauber/Magnetventil.jpg
wolfi_b
Post06-09-2004, 13:13    Subject: Pressure Transducer 1Z Quote
The 1Z connector in the Audi 80 has 3 connections.
[img][/img]
At the end of the lines (red circle), the air filter
is usually located.
I, however, can't think of what the third one is for icon_wink.gif.icon_confused.gif:http://img18.exs.cx/img18/3765/ZKD_1.th.jpg{MARKER}{MARKER}
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
x world one
Post06-09-2004, 13:16    Subject: Pressure Transducer 1Z Quote
I'm not talking about the solenoid valve. I mean the actual pressure sensor for the EGR system. If everyone had a 1Z, it was very well hidden on the old one, at least the diesel filter didn't have a bracket for it.
Well, I thought I had found the solution to the performance issue. "My AGR valve is already defective, so the pressure sensor shouldn't be fulfilling its primary function anymore, right?"
But speaking of that, I have another question.
Can an aged LMM (Lambda Measurement Module) cause increased temperature dependence of the performance in a TDI engine, and be responsible for sluggish acceleration at low engine speeds? My LMM values are still within the acceptable range, but the soot limit is often being reached.
Spritmonitor
Post06-09-2004, 13:20    Subject: Pressure Transducer 1Z Quote
I have a Golf with a 1Z engine (manufactured in December 1995), and as far as I know, the EGR pressure sensor also has a separate bracket (it's all very well hidden under the intake manifold, right next to the turbo).
The temperature. I also have information about dependence and reaching the Russian border.
logged in just the day before yesterday:
Therefore, I'm going to either modify my LMM with the 22 kOhm Ulf version or just use a diode (even though the diode trick didn't work on my ASV).
No new posts Pressure Transducers: Types & Applications Diesel Engine Technology
No new posts Turbo Pressure Sensor: Only 5V? Diesel Engine Technology
This topic is locked, you cannot edit or reply. Unterschied Druckwandler 1H0 906 627 A und 1J0 906 627 A Diesel Engine Technology
No new posts AFN: N75 valve (in VW technical jargon: pressure sensor/c... Diesel Engine Technology
