Clutch Problems: Common Issues and Solutions
merlin
Post08-07-2002, 16:28    Subject: Clutch Problems: Common Issues and Solutions Quote
So,...
When I have an orgasm... sometimes it feels like...
'The clutch would slip! If I pressed the clutch pedal 2-3 times...'
'It's making a 'pumping' sound when idling, then it goes away!' If I understand correctly, my V6 TDI (manufactured in 2000) has a hydraulic clutch... could there be a pressure issue? I've checked all fluid levels... (brakes, power steering, oil... everything is okay). Does anyone else experience this?
Thank you all... this forum is truly invaluable!
M.
Translated on 24-07-2026, 0:29.
Post08-07-2002, 16:33    Subject: Clutch Problems? Troubleshooting and Repair Guide. Quote
merlin wrote:
... sometimes it seems to me as if...
The clutch would pop!
Hi, I don't understand what you mean... ?
Translated on 24-07-2026, 0:30.
merlin
Post08-07-2002, 18:07    Subject: Clutch Problems: Common Issues and Solutions Quote
Hi Rainer, ...
Don't think I'm crazy, but sometimes the clutch engages very abruptly... not me, but the clutch itself. Then there's a muffled 'thump!'
Okay,... this might not belong in this thread,.... but you gave me some advice because my TDI is making a clacking noise,........ I went to another workshop today,........ their assessment was: It's not normal, but it can't be properly localized,........ so we'll just wait and see if it gets worse! Great answer icon_confused.gif.
M.
Translated on 24-07-2026, 0:31.
Post08-07-2002, 18:13    Subject: Clutch Problems: Common Issues and Solutions Quote
Is the clutch slipping? Or is your entire engine/transmission wobbling due to faulty engine mounts or loose mounting bolts? That could also explain the "clacking" sound.
Translated on 24-07-2026, 0:32.
merlin
Post08-07-2002, 18:17    Subject: Clutch Problems: Common Issues and Solutions Quote
Hi Rainer,
I can't really describe the noise; it's like a 'clunk'! As I said, the clutch engages very abruptly with a clacking sound... It's hard to explain. But the idea about checking the screws is good! I'm just not sure how I'm going to get to them, though, because the engine bay is so cramped. Could it be the motor mounts? But surely not at only 38,000 km (miles)?
M.
Translated on 24-07-2026, 0:33.
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3, Quietschgeräusche Kupplung Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sudden performance loss after restart, then okay again Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Kupplung schon wieder defekt! Diesel Engine Technology
No new posts Biodiesel: Answers from the Top Experts Diesel Engine Technology
No new posts Exhaust fumes again! Diesel Engine Technology
No new posts Stuttering in 1Z: Troubleshooting Guide Diesel Engine Technology
