Pressure Vessel 1Z - Larger Size
reuselkopp
Post10-09-2004, 9:32    Subject: Pressure Vessel 1Z - Larger Size Quote
"In my 1Z, the old small pressure sensor is broken. Here in the forum, it's always mentioned that instead of the small one, you should install a larger one. From which vehicle is the larger sensor?"
Translated on 08-10-2026, 5:25.
wolfi_b
Post10-09-2004, 10:18    Subject: Pressure Vessel 1Z - Larger Size Quote
The larger pressure vessel is only beneficial if the VTG (Variable Turbine Geometry) of the turbocharger is difficult to operate.
You have a wastegate turbocharger! icon_wink.gif In my opinion, it's not very effective in that case.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 08-10-2026, 5:26.
reuselkopp
Post10-09-2004, 10:36    Subject: Pressure Vessel 1Z - Larger Size Quote
Thanks... I have a wastegate turbocharger, but the mechanics of the pressure sensor are stiff and sticking! I'm left with only two options: either replace the sensor or try to clean it thoroughly! Are there any experiences or reports available regarding cleaning a pressure sensor or its mechanical linkages?
Translated on 08-10-2026, 5:27.
joreich
Post10-09-2004, 12:51    Subject: Wastgate Valve: How to Adjust & Clean Quote
Hello!
I also occasionally experience the problem of a stuck wastegate valve in my own vehicle.
I always help myself by doing the following:
1) Use a large syringe (at least 50 ml).
2) Disconnect the hose from the pressure sensor to the N75 valve.
3) 1. The person presses firmly on the syringe plunger, forcing fluid into the tube.
4) The second person sprays graphite oil onto the valve of the wastegate.
and gently press down on it with a suitable tool (e.g., a wooden slat).
until the part moves freely.
5) One person then pumps at least 50 times (with assistance).
'...from Person 2), so that the full range of motion can be achieved again.'
It usually works well until a harsh winter with a lot of salt comes along, and the vehicle sits unused for an extended period.
Greetings.
Joachim.
Translated on 08-10-2026, 5:28.
No new posts TDI Pressure Canister 2.5L Diesel Engine Technology
No new posts Test LDR Pressure Canister Diesel Engine Technology
No new posts Aerosol Can on Spray Booth Diesel Engine Technology
No new posts Exchange Pressure Can Diesel Engine Technology
