Steering Angle Sensor: How to Recalibrate? (Solution)
joe
Post05-11-2004, 21:27    Subject: Steering Angle Sensor: How to Recalibrate? Quote
I replaced the steering wheel on a 2000 Audi A6 2.5 TDI Quattro, and also the clock spring (rotary switch).
Now the ESP and ABS systems are indicating that the steering angle sensor is not calibrated.
How can I adjust it using VAG-COM?
Thank you!
Translated on 31-08-2026, 14:01.
haimik
Post06-11-2004, 8:27    Subject: ESP Calibration: Rotary Encoder Adjustment Quote
Look at this! This can only be done with VAG-COM or VAG1551, etc.
http://www.ross-tech.com/vag-com/cars/steeringangle.html
Haimik.
Translated on 31-08-2026, 14:02.
Back to top Profile PM Email
joe
Post06-11-2004, 19:17    Subject: Steering Angle Sensor: How to Recalibrate? Quote
HELLO Haimik,
Okay, that's exactly what I needed. Now I have a problem: my old VW tool only allows login codes up to 32000. I need to find different software.
'Excuse me, do you have any idea where I can find the module codes for the ABS control unit online?'
I stupidly didn't write it down and overwrote it with an invalid one. Damn!
joe
Post19-11-2004, 7:55    Subject: Steering Angle Sensor Calibration: Project Complete Quote
Hello, I'm happy to say that it's been fixed – the steering angle sensor has been recalibrated, and ESP and ABS are working again.
For those of you who might also be considering replacing the steering angle sensor, here are my experiences:
Before starting the modification, you should read the module coding of the ABS control unit using VAG-Com. In my case, this coding had reset to 00000, and I hadn't noted down the original values. After a difficult search on the internet, I was finally able to decipher the procedure and the correct code.
'The module code can only be changed if you know the corresponding login code and the correct module code for the vehicle. The login code is structured as follows: The first digit is followed by a digit that indicates the brake system (FN3/ATE brake: 5; HP2 brake: 4), then a digit that indicates the engine (6-cylinder diesel: 5; 6-cylinder gasoline: 9), and finally a digit that indicates the transmission (6-speed manual: 5; Tiptronic: 7). For my car (FN3 brake, 6-cylinder diesel, Tiptronic), the login code is therefore 07557.'
The module code is structured similarly, but with different numbers: 06 indicates the brake system (FN3 brake 2; HP2 brake 3). The next digit represents the engine (5 for a 6-cylinder diesel, 9 for a 6-cylinder gasoline engine). The following digit indicates the transmission, using the same numbers as in the login process. For my vehicle, the module code for the ABS is 06257.
3. The complete procedure for recoding the ABS module and adjusting the steering angle sensor is as follows:
with VAGcom, the menu codes for VAG1551 are indicated in parentheses.
Function (03): Select brakes.
Login (11)
07557 (This is the login code for a 6-cylinder diesel engine, FN3 brake system, and Tiptronic transmission).
Recode (07)
06257 (This is the module code for a 6-cylinder diesel engine, with FN3 brakes and Tiptronic transmission).
Turn the steering wheel fully to the right and then fully to the left, and then drive a few meters. The steering wheel should now be perfectly centered.
Login (11)
40168
Basic Settings (04)
001
Okay.
It takes some time for the ABS light to turn off (in my case, it was a few minutes). When both the ESP and ABS lights are off, everything is okay.
'Before buying a new retaining ring, you should make sure that the one you have doesn't have the necessary 5-pin connector. Mine did have this connector, which might be related to the heated seats, as there's also a connector for a heated steering wheel. I only noticed this after I had already installed everything. I could have saved myself a lot of money and the adjustment process.'
Okay, if anyone needs one, I still have a replacement ring for a shift paddle steering wheel.
Translated on 31-08-2026, 14:06.
Ratings - Steering Angle Sensor: How to Recalibrate?
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 2 - View ratings
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Programming VW car keys from 1998 onwards Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Model 2014 Key Programming via VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Calibrate steering angle sensor G85 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi A3 8P Steering Angle Sensor G85 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Steering Angle Sensor VW Polo 9N On-Board Diagnostics (OBD)
No new posts Steering Angle Sensor Calibration Issues On-Board Diagnostics (OBD)
