MFA Temperature Display Not Working
Roadrunner505
Karma: +7 / -6   Thank you, like it!
Post12-10-2004, 8:46    Subject: MFA Temperature Display Not Working Quote
Hello, I have a problem: I retrofitted a Multifunction Display (MFA) into my 1996 Passat TDI 1Z.
Everything is working fine.
Distances, averages, oil temperature - only the outside temperature is simply skipped in the menu.
I specifically bought a new sensor and connected it to the white-red and brown-white wires on the speedometer wiring harness. But nothing is displayed...
I've also checked to make sure I haven't reversed the positive and negative terminals – meaning I haven't connected them the wrong way around – ignition on, but nothing happens.
The temperature display simply doesn't appear.
"Who has an idea on how to "activate" it?"
Translated on 27-10-2026, 15:38.
98er_alh
Post12-10-2004, 10:47    Subject: MFA Temperature Display Not Working Quote
"I had a similar experience when retrofitting the Multifunction Display (MFA). Somewhere, I read that after connecting the sensor, the battery needs to be disconnected and reconnected. It seemed unlikely, but it's not much effort - and then, miraculously, it worked."
Andreas
Translated on 27-10-2026, 15:39.
Roadrunner505
Post12-10-2004, 10:52    Subject: MFA Temperature Display Not Working Quote
How long did it have to be disconnected? Just for a very short time, or for a longer period?
And what did the display show before? I've heard from some people that it showed something else.
"It should at least show three lines before it changes - but on mine, it just jumps directly from the oil temperature display to the time."
Translated on 27-10-2026, 15:40.
98er_alh
Post12-10-2004, 10:58    Subject: MFA Temperature Display Not Working Quote
Ist schon etwas her aber eine Minute dürfte genügen. Bei mir waren auch 3 Striche, aber ich habe auch einen G4 und die Instrumente gibt es in x Varianten. PJust try it.
Andreas.
Roadrunner505
Post12-10-2004, 12:20    Subject: MFA Temperature Display Not Working Quote
Given that there are so many variations: Are there any that *don't* display the outside temperature?
Mampf
Karma: +8 / -1   Thank you, like it!
Post13-10-2004, 11:58    Subject: MFA Temperature Display Not Working Quote
Roadrunner505 wrote:
If there are so many variations: Are there any that DO NOT display the outside temperature?
Yes, this is the case in my Passat (03/96 AFN). The vehicle has a Climatronic system ==> the outside temperature is only displayed on the Climatronic's display.
Please check the MFA (Multifunction Display) in check mode to see if it displays the correct outside temperature. In my MFA, it constantly shows -40° and the ice warning (I suspect that the temperature sensor in my Passat is connected to the control unit and not to the instrument cluster, and that the menu option is disabled via a jumper). To access the check mode, you can use the following:
Ignition on.
Hold MFA button.
Turn the ignition off and on again.
Then you can display three different values: current consumption, outside temperature, and oil temperature.
Munch.
Translated on 27-10-2026, 15:42.
Roadrunner505
Post27-11-2004, 16:50    Subject: MFA Temperature Display Not Working Quote
Wow, this is great - it seems like we're on the right track. I'm also getting a -40 Frad reading in this special mode.
If it's currently disabled with a jumper like that, how do I change it?
Translated on 27-10-2026, 15:43.
Mampf
Post27-11-2004, 22:04    Subject: MFA Temperature Display Not Working Quote
Man, this is awesome - this seems like the right track. I'm also getting -40 Frad displayed in this special mode.
If it's disabled with a jumper like that, how do I change it now?
That's the problem, I would also like to know (then I wouldn't have to constantly check the outside temperature display on the Climatronic). That's why I wrote that I suspect it has something to do with the jumper VERMUTE.
Reason: The instrument cluster (IC) in the 35i cannot be accessed via OBD. Furthermore, I only find two different instrument clusters (black displays, 220 km/h scale) for AFN/AHU/1Z engines on www.exist.ru (parts catalog - 2002, in Cyrillic), which correspond to one IC with and one without MFA (Multi-Function Display), but do not allow for any further differentiation regarding the presence or absence of Climatronic.
I thought that since you upgraded the MFA, you might have also discovered any potentially existing jumpers on the back, but apparently that wasn't the case. icon_cry.gif
And I'm not so keen on the display in the AI, that I would build it just to be sure. icon_rolleyes.gif
I actually thought that in your case, the AT commands would be displayed in check mode, and only the display of the value would be disabled in normal mode. Are you absolutely sure that you have connected the temperature sensor to the correct pins? Unfortunately, I can't provide you with a wiring diagram or pinout information.
I'm sorry I couldn't help you.
Munch.
Translated on 27-10-2026, 15:45.
No new posts VW Passat: ESP Light On - What to Do? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K9: Engine Stalling, Error Code 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch, sometimes it works, sometimes it doesn't. Transmission, Chassis, Body & Interior
No new posts 1Z fails to start/shuts down during operation (not relay ... Diesel Engine Technology
No new posts Glow Plug Not Turning Off? Engine Won't Start. Diesel Engine Technology
No new posts Error reading failed On-Board Diagnostics (OBD)
