kossmann Blaumann
2016 Audi Q3 Premium Support
20-09-2004, 18:58 Subject: 4 nozzles with NHG instead of 3 standard nozzles |
Hello everyone,
I just had an idea, which might be a bit silly, but is the following possible:
Instead of using three "standard" injector shafts and one shaft with an NHG (Needle Lift Generator), could you also use four needle lift generators and only connect the one for the third cylinder?
Nowadays, you can find rebuilt needle lifter injectors everywhere, and sometimes they're even cheaper than new injector bodies without a needle lifter.
Profile PM Email Garage |
Rudi Guest
20-09-2004, 19:06 Subject: 4 nozzles with NHG instead of 3 standard nozzles |
Hi Tino,
The thing is, the nozzles with the NHBF designation are longer than the 'standard' ones, and...
High-pressure pipelines are not suitable for this application at this time. If you can obtain the necessary connections (in both directions),
It should work.
Best regards, Rudi.
20-09-2004, 22:30 Subject: 4 nozzles with NHG instead of 3 standard nozzles |
... and the cable length must not be changed!!!
They must be exactly the same length, which is why the seemingly nonsensical curves are there.
Profile PM Garage |
