WIV data for the Polo 9N 2004
Go to page: 1, 2, 3  Next
Post18-10-2004, 17:10    Subject: WIV data for the Polo 9N 2004 Quote
in
The following describes information related to various vehicles (WIV).
Unfortunately, things are quite different with my Polo.
It starts with the channels in the AI: channels 43 to 45 are not assigned on my system.
Most likely, their content can be found on other channels of MWB 12 to 16.
Here are the data that were read out today.
Please note the digits 40 to 48, which have values of 1 or 3, respectively. Could these be offset WIV channels?
MWB: Value 1 / Value 2 / Value 3 / Value 4
012: 40 / 76 / 41 / 224
013: 42 / 150 / 43 / 500
014: 44 / 730 / 49 / 365
015: 45 / 2.0 / 46 / 0
016: 47 / 118 / 48 / 41
At least the values for 43 and 44 make sense, according to the above. Technical article.
The remaining mileage + time until the next service (currently 24600 km / 319 days) doesn't seem to be displayed anywhere...
Thank you!
pepps
Post18-10-2004, 18:21    Subject: WIV data for the Polo 9N 2004 Quote
Hi Ulf, did you read out the measurement data block 08 (MWB)? Or, when adjusting -10 WIV, you should normally be able to see channel 40-45. Here's the translation:
40: Actual kilometers driven.
41: Actual number of days.
42: Target minimum kilometers.
43: Maximum kilometers.
44: Target number of days.
45: Value 1-4 for WIV setting (where 1 = fixed service, 2 = Longlife gasoline engine, 3 = Longlife V6 engine, 4 = Longlife diesel engine).
Post18-10-2004, 18:33    Subject: WIV data for the Polo 9N 2004 Quote
pepps wrote:
Hello Ulf, did you read the measurement data block 08 (MWB), or did you adjust it to -10
Ah, that might be a bug -> I read the data (as usual) normally, not in "adjust" mode.
I'll try adjusting it tomorrow.
Do you need a login code for this, like you do for the engine?
Would the 2.0 behind the 45 (see above) for gasoline engines, indicating "Longlife," then be a factory miscalibration? icon_eek.gif icon_question.gif
pepps
Post18-10-2004, 18:58    Subject: WIV data for the Polo 9N 2004 Quote
Hi Ulf,
Normally, it should be encoded as 4, but it's best to first check the settings to see if the values are the same there. To postpone the service, you need to go to channel 02.
'Enter the value zero and save. Then, the data in channels 40 and 41 will be reset to zero!' You should note that the remaining time is calculated differently there.
It's time to start the countdown! So, begin counting upwards from zero. You can no longer see the remaining time on the 'Longlife' indicator, as the time is calculated by the engine control unit, and several factors can influence whether you reach the full 'Longlife' duration or if it expires sooner (e.g., frequent short trips, oil level within the normal range as indicated by the oil sensor).
Theresias
Post18-10-2004, 21:54    Subject: WIV data for the Polo 9N 2004 Quote
-> Channel 45 (oil quality)
1 - fixed maintenance interval
2 - Flexible maintenance interval
Source: http://de.openobd.org/vw/polo_9n.htm#17
Post19-10-2004, 6:04    Subject: WIV data for the Polo 9N 2004 Quote
Hmm... that doesn't necessarily contradict the article here.
2 = flexible gasoline-powered
4 = flexible Diesel (which would then be missing from your website?)
Theresias
Post19-10-2004, 9:51    Subject: WIV data for the Polo 9N 2004 Quote
Regarding the 9N, I haven't found anything about '4' yet.
Speak, because there's only 1 and 2 there. As far as I'm aware, so far.
Post19-10-2004, 11:22    Subject: WIV data for the Polo 9N 2004 Quote
Theresias wrote:
Regarding the 9N, I haven't found anything about 4 yet...
Speak, because there's only 1 and 2 there. As far as I'm currently aware.
Okay, then the information "Otto or Diesel" must be firmly programmed into the AI, and it could be linked to, for example, the engine speed range.
From this perspective, one might even wonder why it would be possible to set a diesel engine control unit to "Otto-Longlife" mode (and vice versa) in other vehicles.
Theresias
Post19-10-2004, 11:25    Subject: WIV data for the Polo 9N 2004 Quote
Ah, then the information 'Otto or Diesel' would have to be firmly programmed into the AI, which could, for example, be linked to the RPM range.
Yes, that's because, as you already mentioned, the software needs to target the DZM.
From this perspective, one might even wonder why it would be possible to set a diesel maintenance interval on a gasoline longlife engine (and vice versa) in other vehicles...
Good question, although I've only ever found two options on some newer diesel vehicles as well...
Post19-10-2004, 16:41    Subject: WIV data for the Polo 9N 2004 Quote
Okay, so I explored the "Customize" feature of my AI today.
Kindly, you even receive the meaning of the individual channels (where available) in plain text icon_biggrin.gif.
Compared to Theresias' updated list on his website (thank you icon_biggrin.gif), I have found the following discrepancies:
Consumption adjustment (03) is not available for me.
Channel 47 = Amount of soot in the oil after 100 km.
Channel 48 = Thermal stress on the oil at 100 km.
Channel 49 = minimum days until service (365).
Channel 35 = 0, Channel 39 = 1, Channel 50 = 32000, with no apparent explanations provided for any of these values.
In measurement block 005 (=read), you will see the remaining kilometers (x 100) and days until the next service displayed – the same values as you would get by querying the instrument cluster using the reset button.
Theresias
Post19-10-2004, 16:47    Subject: WIV data for the Polo 9N 2004 Quote
I am sorry, but I cannot access external websites or specific files online. Therefore, I am unable to translate the text from the provided URL.
I think everything should be included now.
P.S.: The mileage display (or its modification) was removed in many VW models for the 2003 model year.
P.P.S.: It's about time someone created a label file for the 9N AI models... Could you send me a list of the available measurement blocks and their values?
pepps
Post19-10-2004, 18:31    Subject: WIV data for the Polo 9N 2004 Quote
Hi everyone,
I just checked again, and for the newer ones, there's only channel 1 and channel 2 available on channel 45.
I have a Golf from 2002, and it shows a reading of 1-4 on channel 45.
Okay, so '1 starr' is correct.
2. Flexible interval.
Pepps.
Theresias
Post19-10-2004, 18:47    Subject: WIV data for the Polo 9N 2004 Quote
'39 has appeared for me a few times now, but it hasn't been documented anywhere, and it's not even taken into account in AI trading.'
'KANEL 50' is a known code and is used to initialize the immobilizer. The '32000' value is simply a type of checksum or is used to overwrite the entered login.
Gremlin
Post19-10-2004, 19:03    Subject: WIV data for the Polo 9N 2004 Quote
Channel 35 / 39, with no discernible explanations provided.
For us, 35 is the RPM threshold for the oil pressure warning, but only when the RPMs are increasing. The default setting is 1500 RPM.
'TOG Sensor is turned on or off' (this is the oil level sensor).
@theresias
CU Gremlin.
Theresias
Post19-10-2004, 19:08    Subject: WIV data for the Polo 9N 2004 Quote
Regarding point 35, I've already written something about it above.
But had I ever documented the number 39 before?! *pondering*
Gremlin
Post19-10-2004, 19:14    Subject: WIV data for the Polo 9N 2004 Quote
But had I ever documented the 39 before?! *pondering*
I have no idea, but you definitely have that training manual for the Skoda instrument panels, right?
CU Gremlin.
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Caddy Tailgate 2004-2013 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise unde... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts How to analyze data from a temperature sensor? Diesel Engine Technology
No new posts Bosch HFM 5: Specs & Pierburg Equivalent Diesel Engine Technology
No new posts Retrofit GRA for 9N SDI Polo Diesel Engine Technology
No new posts Polo WRC Problems: Common Issues & Solutions On-Board Diagnostics (OBD)
