Exhaust Manifold Gasket Replacement: Steps & Guide
Post26-09-2004, 1:29    Subject: Exhaust Manifold Gasket Replacement: Steps & Guide Quote
Hi.
I discovered a leak in the crankshaft seal.
http://www.luxus-wg.de/~martin/auto_bilder/abgas_undicht2.jpg
If I want to make this new now, I'll probably have to take it apart quite a bit.
My "how-to" guide doesn't say anything about it at all.
What all do I need to do?
- Turbo from Kruemmer?
- Remove the shielding plate from the Krümmer!
- Remove the crumb tray and its 8 screws!
How do I turn the 12 Kantschrauben Turbo-Kruemmer?
Does the turbo arrive without a seal and dry at the crumple zone?
What happens to the head studs? Do they stay in the head, or are they replaced?
I don't feel like taking the thing to VW to have it completely taken apart, so I have to do it myself icon_smile.gif[/url].
Translated on 30-08-2026, 8:23.
Manuel Thomas
Post26-09-2004, 8:54    Subject: Exhaust Manifold Gasket Replacement: Steps & Guide Quote
The turbo stays on the manifold. Only the oil lines and exhaust system need to be removed.
Manuel.
Translated on 30-08-2026, 8:24.
Post26-09-2004, 9:15    Subject: Exhaust Manifold Gasket Replacement: Steps & Guide Quote
Hm,
"But how do I reach the lower bolt on cylinder 2, since the fresh air pressure connection from the turbo is located directly in its line of sight?"
http://www.luxus-wg.de/~martin/auto_bilder/AGR_Saugstutzen/von_oben_im_weg.jpg
Translated on 30-08-2026, 8:25.
olli
Karma: +46 / -0   Thank you, like it!
Post26-09-2004, 12:42    Subject: Exhaust Manifold Gasket Replacement: Steps & Guide Quote
If you don't have the option of breeding a mouse that will replace the mother for you, then it's probably easier to remove the turbo from the exhaust manifold. You should be able to loosen the 12-point screws with a regular 12-point socket.
Stud bolts are typically not replaced unless the nuts are already seized on them, or a thread breaks during removal.
I would definitely replace the nuts, and when assembling, I wouldn't be stingy with the copper grease.
Olli.
A6 CANA/JME /
Ex-A6 AEL
Translated on 30-08-2026, 8:26.
haehnlein
Post27-09-2004, 19:52    Subject: Exhaust Manifold Gasket Replacement: Steps & Guide Quote
olli wrote:
I would definitely replace the nuts, and when assembling, don't be stingy with the copper paste.
"Be sure to spray it thoroughly with rust remover beforehand! I use 'Anti-Seize' for preservation."
On my 1z, the exhaust manifold came off without removing the turbo (only the heat shield had to be unscrewed). However, I also had the cylinder head lying on the workbench icon_eek.gif.
____________
Kein Auto mehr!
Translated on 30-08-2026, 8:27.
No new posts Replace AVF coolant regulator Diesel Engine Technology
No new posts Replace coolant hose (AFN) Diesel Engine Technology
No new posts Piston Rings Replacement: Audi 2.5L AEL/AAT Diesel Engine Technology
No new posts Timing belt replacement: What else should be replaced at ... Diesel Engine Technology
