Exhaust Leak: Causes and Solutions
Post25-09-2004, 18:46    Subject: Exhaust Leak: Causes and Solutions Quote
Hi.
The crap never ends.
The intake manifold is detached and the cylinder... (away from the transmission, so number 1??), is covered in grime.
http://www.luxus-wg.de/~martin/auto_bilder/abgas_undicht.jpg
http://www.luxus-wg.de/~martin/auto_bilder/abgas_undicht2.jpg
It looks like it's going to take a really long time now, because if I've already taken everything apart, I probably have to replace the gasket too, otherwise my head might end up catching fire eventually.
Does the turbo need to be removed from the crankshaft?
I suspect that's the case, because otherwise you can't get to the screw on cylinder 2, as the turbo fresh air outlet pipe is in the way. icon_evil.gif icon_evil.gif icon_evil.gif
I should have left it alone icon_smile.gif.
Translated on 05-08-2026, 16:10.
Acid-2000
Post27-09-2004, 22:57    Subject: Exhaust Leak: Causes and Solutions Quote
Hi!!!
So, the job isn't that bad.
I once installed them on my new [device/item], without using the included accessories.
to dismantle it. And in the process, I even had to re-tap a thread icon_sad.gif.
But whatever...
Exhaust system removed. Screws loosened. I hope this helps you.
It's just a little bit involved. And the rest, you probably already know.
Definitely replace the studs and copper nuts.
Gut.. Stehbolzen muss du schauen, wie die aussehn. I'm currently building something.
Always use copper grease with those things to prevent them from seizing up.
It works perfectly for me.
Regards, Acid.
Translated on 05-08-2026, 16:12.
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B2 CV Joint Leak: Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T6 Windshield Washer Fluid Leaking, Washer Fluid Tank Dam... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbo Exhaust Flange Leak: Troubleshooting Guide Diesel Engine Technology
No new posts Fixed Issue, New Problem Arises Diesel Engine Technology
No new posts Leaky AVF AGR Valve: Causes & Fixes Diesel Engine Technology
No new posts Cylinder head cover leak AMF Diesel Engine Technology
