Electric Starter Problems: Troubleshooting Guide
noti
Post30-09-2004, 10:13    Subject: Electric Starter Problems: Troubleshooting Guide Quote
My electric vehicle suddenly lost power on the highway last Friday.
The engine just stopped working. I then had the ADAC (German Automobile Club) tow it home.
While troubleshooting, I discovered that the power supply was only outputting 7V.
'Zündung an' bekommt. Die Batterie selber hat aber noch 12V. The problem is just that...
I don't have a wiring diagram for my Skoda pickup truck. I once tried something out as a test.
If you apply 12V directly from the battery to the solenoid, you will hear it activate.
click.
Now my question: Is the starter motor switched via a relay or directly at the ignition switch?
Or what else could it be due to?
The notification.
Translated on 09-10-2026, 1:06.
Gremlin
Post30-09-2004, 10:19    Subject: Electric Starter Problems: Troubleshooting Guide Quote
As far as I can remember, the 12V comes directly from the ignition switch.
Just check with www.skodacommunity.de.
CU Gremlin.
Translated on 09-10-2026, 1:07.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN Wiring Harness Pinout T68 Connector Diesel Engine Technology
No new posts T4 7H Electrical System Electrical Systems, Vehicle Electronics, Multimedia
No new posts Electrical Lighting: Solutions & Ideas Transmission, Chassis, Body & Interior
No new posts Electrical Question: Get Answers Now! Diesel Engine Technology
