V6 TDI fuel injection pump problem
golf 3 pd tdi
Post02-10-2004, 12:13    Subject: V6 TDI fuel injection pump problem Quote
Hello, is it possible for a V6 TDI fuel injection pump to 'learn'? We installed such a fuel injection pump in a V6 TDI with a manual transmission. Previously, it was in a V6 TDI with a Tiptronic transmission. Otherwise, everything was the same as in the V6 TDI with an automatic transmission. Could it be that the fuel injection pump's computer 'learned' from the engine control unit of the V6 TDI with the automatic transmission when it was installed? And if we plug it into a different car, will some data from the engine control unit with the manual transmission be missing? The car is running, but it lacks power. And if I'm right, is there some software that allows me to overwrite the computer in the V6 TDI fuel injection pump?
WarLord
Post02-10-2004, 14:10    Subject: V6 TDI fuel injection pump problem Quote
As far as I know, the VP44 has its own control unit. You can take a look at that if you like.
Best regards, WarLord.
Rudi
Post02-10-2004, 15:15    Subject: V6 TDI fuel injection pump problem Quote
As far as I know, the VP44 has its own control unit. You can take a look at that sometime.
Dear icon_cool.gif, The control unit is designed as a hybrid and is located inside the pump.
Nothing can be done or observed about that part.
Best regards, Rudi.
WarLord
Post02-10-2004, 19:32    Subject: V6 TDI fuel injection pump problem Quote
I'm not saying he should take the pump apart, but rather that he should use a VAG-Com to check it.
Manuel V
Post03-10-2004, 19:40    Subject: V6 TDI fuel injection pump problem Quote
Hello, the control unit needs to be programmed to the corresponding transmission.
You can't simply operate an engine control unit (ECU) that's programmed for automatic transmission with a manual transmission.
Best regards, Manuel.
Manuel V
Post04-10-2004, 19:04    Subject: V6 TDI fuel injection pump problem Quote
I've sent you the encoding table via private message. It should also be possible with VAG Com.
golf 3 pd tdi
Post08-10-2004, 22:32    Subject: V6 TDI fuel injection pump problem Quote
Hi Manuel V., I've sent you a private message!
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts VTG Problem: Troubleshooting & Solutions Diesel Engine Technology
No new posts agr new problem Diesel Engine Technology
No new posts Cruise Control Problems: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Central Locking Problem: Troubleshooting Guide Transmission, Chassis, Body & Interior
