Are rear door speaker wires already pre-installed in the G4?
Hati
Post07-10-2004, 16:09    Subject: Are rear door speaker wires already pre-installed in the G4? Quote
Hi.
I want to retrofit speakers in the rear doors of my 'new' G4 Special (03/2002). From the factory, it came with an Alpha 5 (which looks like a Beta) that is being replaced with a CD tuner. Are the speaker cables already pre-wired to the rear doors from the factory, or do the cables need to be painstakingly run from the front to the back? icon_confused.gif
Julian
Post07-10-2004, 17:41    Subject: Are rear door speaker wires already pre-installed in the G4? Quote
Well, it's not that difficult. Normally, they are not installed that way from the factory.
R.M.
Karma: +14 / -0   Thank you, like it!
Post07-10-2004, 18:25    Subject: Are rear door speaker wires already pre-installed in the G4? Quote
I also think there won't be any cables there (those days are over at VW), at least there weren't any in my 1998 Passat.
It takes a bit of work. Since everything is glued together and not screwed, you should expect relatively high stress concentrations on the plastic parts. The rubber grommets on the doors were a tight fit for me.
And you'll need new speaker grilles for the rear speakers, as the old ones are likely damaged (or "deaf"), and depending on the type of speaker, you might also need an adapter frame. However, none of this will cost a fortune.
R. M.
Holger247
Post11-10-2004, 13:00    Subject: Are rear door speaker wires already pre-installed in the G4? Quote
So, in my case, there were no cables included.
Installing the part on the 4-door model through the rubber bellows is not a problem. The grilles were also permeable in my case. LS-distance rings are needed because otherwise the speakers would protrude too far into the door.
To run the cables, carefully remove the lower B-pillar trim (be careful of the seatbelt pretensioners).
Depending on where you want to run the cables, you may also need to remove the center console.
If you are laying separate HT cables, you will need to attach the switch to the door frame; I had to improvise a bit to do that.
If you obtain the crimping tools, you can plug the LS cables into the original connectors.
GIV - 98 - ALH
Touran 5T 2.0 TDI
Hati
Post13-10-2004, 17:34    Subject: Are rear door speaker wires already pre-installed in the G4? Quote
Okay.
It worked perfectly. Fortunately, the covers were 'porous,' so none of them needed to be replaced.
No new posts Golf 3: Rear Door Corrosion - Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 2000: Rear Brake Noise Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentary, low-frequency noise from rear brakes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts How do I get speaker wire into the rear doors? Diesel Engine Technology
No new posts Central Locking: Rear Doors Won't Open? Electrical Systems, Vehicle Electronics, Multimedia
No new posts Rear Door Problems: Sensor Not Detecting Opening On-Board Diagnostics (OBD)
No new posts HB4 Blind from Factory: Causes & Fixes Transmission, Chassis, Body & Interior
