TDI Timing Help: Strange Error Message?
hb2000
Post12-10-2004, 21:27    Subject: TDI Timing Help: Strange Error Message? Quote
hello
I once tried using VCDS to check the TDI timing and received a message that made me a bit concerned: 'timing is too advanced to be plotted.' After putting in a lot of effort to get the engine temperature to 85 degrees Celsius, I received this message. The car is a Passat 3B, TDI, AJM with 115 hp. Is it really possible that the timing is that far advanced, or is this message just a joke? The car seems to be running fine overall and sounds like any other PD diesel. The timing belt was replaced at 120,000 km, and now the car has 155,000 km on it and should still be working for a while. I would appreciate any answers that can help me with this.
Best regards.
hb2000
Translated on 11-10-2026, 3:57.
wolfi_b
Post13-10-2004, 6:27    Subject: TDI Timing Help: Strange Error Message? Quote
The error message simply means that the injection point is outside the visible range.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 11-10-2026, 3:58.
hb2000
Post13-10-2004, 8:07    Subject: TDI Timing Help: Strange Error Message? Quote
But the Passat is actually running perfectly fine - shouldn't that be noticeable???
Translated on 11-10-2026, 3:59.
wolfi_b
Post13-10-2004, 8:21    Subject: TDI Timing Help: Strange Error Message? Quote
Normally, yes, due to factors like poor starting behavior and increased fuel consumption.
Now I've looked it up: AJM is actually a PD engine. I somehow assumed it was a VP, and unfortunately, I'm also unsure about the injection start timing for PD engines. icon_confused.gif
1993 Audi 80 B4 1Z
Michael II
Post13-10-2004, 8:29    Subject: TDI Timing Help: Strange Error Message? Quote
What do the data blocks indicate?
Tschüss
Michael II
Translated on 11-10-2026, 4:00.
MichaelJ
Post13-10-2004, 9:23    Subject: TDI Timing Help: Strange Error Message? Quote
Could it be that, in a PD (Pump-Düse) engine, the TDI-Timing function (TDI-Graph) simply doesn't work at all? icon_rolleyes.gif
On the TDI-Timing website, it states:
Quote 1:
Note: This DOES NOT apply.
to 1.9 PD (unit injector) engines.
Quote 2:
Note to 1.9 PD (pump düse, also unit injectors) owners: you cannot, and do not need to, set your timing electronically. There are no graphs published for the simple reason that the timing is set using a dedicated VAG locking tool when changing the timing belt icon_smile.gif.
I translated it in a way that indicates there are no electronic adjustments for the PD motor.
but rather the start of injection using a VW tool (similar to the round pin used in the VP-ESP).
Greetings.
MichaelJ
Audi 80 TDI , MKB: 1Z, KM >455.000 r.i.p.
Passat 3B TDI, MKB: AJM, KM >331.000 r.i.p.
Audi A4 Cabrio Quadro, MKB: ASB KM> 119.000 -ZKD defekt, 6 Zylinder voller Riefen ATM 16tsd €! ATM 2 Tage vor Garantieende getauscht, da drei defekte Injektoren zwei Jahre lang nicht getauscht wurden.
Translated on 11-10-2026, 4:01.
Post13-10-2004, 9:58    Subject: TDI Timing Help: Strange Error Message? Quote
"Those who can search have a clear advantage."
/viewtopic.php?t=5408&highlight=misconfiguration+pd
/viewtopic.php?t=5257&highlight=setting
Translated on 11-10-2026, 4:02.
MichaelJ
Post13-10-2004, 11:01    Subject: TDI Timing Help: Strange Error Message? Quote
@BertilViewing profile: Bertil
Thank you for the links - now I can imagine how to adjust a PD motor.
It works, if I ever happen to have a TDI with a PD engine icon_wink.gif.
But my statement that TDI timing only works with VP engines - and that's why...
Greetings.
Michael.
Translated on 11-10-2026, 4:03.
Karma: +805 / -0   Thank you, like it!
Post13-10-2004, 11:11    Subject: TDI Timing Help: Strange Error Message? Quote
Yes, the TDI timing checker is only for engines with a distributor injection pump.
Translated on 11-10-2026, 4:04.
hb2000
Post13-10-2004, 21:16    Subject: TDI Timing Help: Strange Error Message? Quote
Thanks for the info - I probably could have figured that out myself.
The PD (phase difference) is only adjustable using the dial indicator; nothing else works.
Translated on 11-10-2026, 4:05.
joergs
Post13-10-2004, 21:20    Subject: TDI Timing Help: Strange Error Message? Quote
What are you talking about? Are you referring to the timing or the preload setting of the PDEs? *looks questioningly*
hb2000
Post15-10-2004, 10:28    Subject: TDI Timing Help: Strange Error Message? Quote
*valve timing*
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI-Graph error message "Timing to advanced" On-Board Diagnostics (OBD)
No new posts Exhaust Gas Recirculation (EGR) Error: Deviation. Diesel Engine Technology
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Wrong Oil in Porsche? Get Help Now! Diesel Engine Technology
