Diesel filter and the funny spider: What kind of wrench?
WarLord
Post18-10-2004, 17:31    Subject: Diesel filter and the funny spider: What kind of wrench? Quote
Since I have removed the diesel filter's drain, and as a result, the part is no longer completely sealed (especially at the bottom, and the VW engineers also haven't made it completely sealed), I'm interested in knowing what size wrench/socket is needed to get a replacement. Separating the filter from the spider should be quite simple, right? (just unscrew it or something)
Okay, the vehicle is a Passat 3B with a 115 PS PD engine.
Can anyone perhaps provide me with the part number for a new fuel filter?
Best regards, WarLord
pepps
Post18-10-2004, 18:10    Subject: Diesel filter and the funny spider: What kind of wrench? Quote
Hello, this is a 13mm Allen wrench, but it also works with a 12mm one if the screw isn't too tight! icon_biggrin.gif
WarLord
Post18-10-2004, 18:16    Subject: Diesel filter and the funny spider: What kind of wrench? Quote
Well, hopefully they will also have it as a spare part. My car already looks a bit damaged.
But okay, then I'll get a 13mm wrench.
daytrader
Post18-10-2004, 18:29    Subject: Diesel filter and the funny spider: What kind of wrench? Quote
I always meant it was an im bus and not an in bus, but I guess I was a little off.
siehe also hier: http://de.wikipedia.org/wiki/Inbus
MWeid
Post19-10-2004, 7:43    Subject: Diesel filter and the funny spider: What kind of wrench? Quote
I always meant it to say 'I'm' and not 'in', but I guess I was a little off
Greetings,
Mathias
WarLord
Post19-10-2004, 17:46    Subject: Diesel filter and the funny spider: What kind of wrench? Quote
Hm, can someone quickly tell me how to separate the filter from the spider and whether it's a major mess?
joergs
Post19-10-2004, 18:22    Subject: Diesel filter and the funny spider: What kind of wrench? Quote
In normal cases, it should come loose. The whole thing shouldn't really be so tightly connected. A little bit of diesel is also leaking out. But a suitable rag helps with that...
No new posts Subject: Extending Diesel Filter Replacement Interval Troubleshooting & Guides
No new posts Funny starting problems Diesel Engine Technology
No new posts VW Passat: Strange MWB 1/2 & 8 Readings On-Board Diagnostics (OBD)
No new posts Turbocharger Leak: Funny Discovery! Diesel Engine Technology
No new posts Charging control is acting up Electrical Systems, Vehicle Electronics, Multimedia
