Hello.
I got a genuine VW exhaust pipe for a Golf 3 TDI with a 1Z engine for a cheap price some time ago.
It's connected to the catalytic converter.
Image 1: Trouser leg.
http://www.sammlerautos.de/tdi1zhosenrohr2.jpg
Okay, everything is prepared for installation (the old one is damaged at the flexible pipe), the car is raised on jacks, and I've placed it under the car. I thought I was seeing things, but it turns out the catalytic converter and the exhaust pipe are actually one piece
Image 2: Exhaust pipe on the car.
http://www.sammlerautos.de/tdi1zhosenrohr1.jpg
Something like with the AFN, AHU, and I think also with the ALE.
What's underneath mine can't be from either the AFN or the AHU engine. The AFN has two additional brackets on the front, and the AHU one looks different as well.
The car is a Golf 3 Variant, manufactured in February 1996, with a 1Z engine.
Has anyone ever seen this on a 1Z before, or has anyone installed any aftermarket parts under it?
Can I now also install the catalytic converter and exhaust pipe combination from an AFN or AHU engine in my car?
Is the pipe diameter behind the catalytic converter correct?
togu
