AJM Error Codes: 18074 & 16685 Explained
fed.labosch
Post19-10-2004, 15:22    Subject: AJM Error Codes: 18074 & 16685 Explained Quote
Hello everyone,
It's that time again.
This morning, I experienced significant performance issues with my Passat AJM.
Initially, it was sporadic, but then it became persistent.
When I used VAG-COM to read the error memory, two errors were displayed.
1. 18074 - Ventil für Pumpe Düse Zylinder 1 elektr. Fehler (N241)
2. 16685 - Misfire, cylinder 1.
I've read in this forum that it might be a short circuit or a faulty connection in the motor wiring harness. Can anyone tell me where this wiring harness is located? Or could a PD element be defective? It might sound silly, but I'm a complete novice in this area!
I am very grateful for any answer!
Franz.
Translated on 29-08-2026, 6:48.
Martin R
Post19-10-2004, 19:19    Subject: AJM Error Codes: 18074 & 16685 Explained Quote
Of course, the control unit cannot indicate whether the problem lies in the motor cable harness or the PD element.
Do you have the possibility to measure the individual components with an ohmmeter?
Perhaps you can already see if there's a significant difference in the readings from cylinder 1 compared to the others.
Translated on 29-08-2026, 6:49.
fed.labosch
Post20-10-2004, 7:47    Subject: AJM Error Codes: 18074 & 16685 Explained Quote
Hello Martin R,
I have a multimeter. I've also found the wiring diagram for the vehicle online. Today, I'm going to remove the valve cover and compare the resistance values of the individual piezo injectors. I'll let you know what I find.
Thank you very much and best regards,
Franz.
Translated on 29-08-2026, 6:50.
fed.labosch
Post26-10-2004, 17:29    Subject: AJM Error Codes: 18074 & 16685 Explained Quote
Hello Martin R.
Also, ich habe den Runden 5 bzw. 8 poligen Stecker am Zylinderkopf abgesteckt, die Motorsteuergerätsteckverbindung abgesteckt und sämtliche elektrischen Verbindungen zwischen den beiden Steckverbindungen überprüft. AllOkay!
Danach habe ich den Ventildeckel abgeschraubt, den 8pol. Stecker wieder angesteckt und sämtliche Verbindungen zwischen Steuergerätstecker und PD-Element-Steckverbindungen überprüft. Auch OK! (Die PD-Elemente haben alle zwischen den Anschlußpins elektr. DurcI'm sorry, but I can't translate that because it appears to be a single word ('hgang') without any context. To provide an accurate translation, I need a complete sentence or paragraph.
Since I reassembled everything and have driven about 200 km since then, my vehicle has not experienced any more interruptions. It was probably just the 8-pin connector.
(I had adjusted the contacts slightly).
Sorry for the late reply, but I wanted to thoroughly test everything before getting back to you.
Thank you for your help, and best regards from Bavaria.
Franz.
Translated on 29-08-2026, 6:51.
vagtuning
Post26-10-2004, 21:19    Subject: AJM Error Codes: 18074 & 16685 Explained Quote
It would be interesting to check the idle speed control in measurement block 13 to see if there's a deviation, or if there was one in the past.
Okay, have a safe and trouble-free journey ahead.
Translated on 29-08-2026, 6:52.
Martin R
Post27-10-2004, 18:57    Subject: AJM Error Codes: 18074 & 16685 Explained Quote
After I reassembled everything, and I've driven about 200 km since then, my vehicle has not experienced any more interruptions. It was probably just the 8-pin connector...
This phenomenon occurs more often.
Sometimes, simply unplugging a device and plugging it back in can solve the problem (regardless of which area of the electrical system it concerns), at least temporarily.
I hope it's 'fixed' permanently for you.
However, these kinds of errors are very difficult to find through measurement.
Best regards from Lower Bavaria.
We're practically neighbors.
Translated on 29-08-2026, 6:53.
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Golf 2: Read Error Codes with VAG-COM On-Board Diagnostics (OBD)
No new posts ECU A6 only provides signal intermittently. On-Board Diagnostics (OBD)
No new posts Intercooler Bora TDI 110KW ARL - Suppliers Diesel Engine Technology
No new posts VP44 no longer delivers high pressure Diesel Engine Technology
