Golf III Variant 1.9 TDI: Problems & Issues
Bluna
Post16-11-2004, 21:28    Subject: Golf III Variant 1.9 TDI: Problems & Issues Quote
Hello!
I currently still drive a gasoline-powered car (a VW Polo 6N2 1.4).
Having driven almost 95,000 km in just under 3 years, I'm now starting to consider a diesel car.
I would appreciate some tips and advice on what to consider when buying...
Things to watch out for when buying a Golf III Variant 1.9 TDI.
Here are the vehicle details:
First registration: 06/1996
Engine: 1.9 TDI 110 hp (chipped - but I don't know which chip was used).
Mileage: 280,000 km (new engine installed at 191,000 km).
Unfortunately, I don't know any more than that.
Hoffe Ihr könnt mir ein paar Infos geben. Thank you!
Marco
Translated on 29-10-2026, 11:09.
Marco
Post16-11-2004, 22:15    Subject: Golf III Variant 1.9 TDI: Problems & Issues Quote
If it's been chipped and doesn't even have a basic understanding of what that entails, alarm bells should definitely be ringing. Furthermore, the (new) engine likely needs a new timing belt after approximately 1000 km.
Translated on 29-10-2026, 11:11.
Bluna
Post16-11-2004, 22:18    Subject: Golf III Variant 1.9 TDI: Problems & Issues Quote
So, I don't have any information about the chip yet. It should be coming from them here.
What about the timing belt? Should it be replaced every 90,000 km?
Marco
Translated on 29-10-2026, 11:12.
Marco
Post16-11-2004, 22:31    Subject: Golf III Variant 1.9 TDI: Problems & Issues Quote
Tuning a TDI isn't a big deal if the owner treats the car properly. However, if the seller gives the impression that the car has been driven aggressively, I would stay away from it. For the AFN engine (if it is indeed an AFN), the ZR service is likely due every 90,000 km.
Bluna
Post16-11-2004, 22:36    Subject: Golf III Variant 1.9 TDI: Problems & Issues Quote
Thank you for the information!
What about fuel injection and similar technologies?
Are these vulnerable?
Marco
Translated on 29-10-2026, 11:13.
Post16-11-2004, 23:25    Subject: Golf III Variant 1.9 TDI: Problems & Issues Quote
If all the auxiliary components (alternator, starter, water pump, fuel injection pump) have already reached 280,000 km, it's probably a good idea to start saving up for replacements... that's my opinion.
And if the engine is a 1Z, you should check if the fixed bolt (grade 12.9) on the crankshaft sprocket is present and if there have been any problems with it before.
Translated on 29-10-2026, 11:14.
Bluna
Post17-11-2004, 6:58    Subject: Golf III Variant 1.9 TDI: Problems & Issues Quote
...And if the engine is a 1Z, you should check if the fixed bolt (12.9) on the crankshaft sprocket is present, and whether there have been any problems with it before.
How am I supposed to understand this now? Sorry, I don't know much about diesel engines or the Golf III yet.
Marco
Translated on 29-10-2026, 11:15.
Post17-11-2004, 10:52    Subject: Golf III Variant 1.9 TDI: Problems & Issues Quote
Hi Bluna.
I think you know far too little about the car!
You wouldn't seriously buy a car that has "no idea" how many horsepower it has, let alone whether that's even officially registered.
Is it a 90 HP engine that has been chipped to 110 HP, or an 110 HP engine that has been chipped to a higher power output (xxx HP)?
Regarding the crankshaft bolt, please read this when it is unlocked again:
http://home.arcor.de/sgrafen/salatoel/kw_schraube/kw_schraube.html
or search here in the forum.
Furthermore, 280,000 km is quite a mileage, so you shouldn't expect a car in perfect condition – you'll likely have to replace quite a few parts in the next two years!
Translated on 29-10-2026, 11:16.
Bluna
Post17-11-2004, 16:36    Subject: Golf III Variant 1.9 TDI: Problems & Issues Quote
I already said that I have no knowledge of Volkswagen diesel technology. That's why I'm asking.
It's originally a 1.9 TDI engine with 110 horsepower. It has been chipped, but I don't know yet which chip was used.
I haven't had a chance to really examine the car yet.
That's why I want to know what I should pay attention to, where the weaknesses are, etc.
But thank you for the link.
Marco
Translated on 29-10-2026, 11:17.
No new posts Tankklappenentriegelung failure Golf 5 Variant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 Problems: Tailgate/Rear Door Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J1587: Haldex Control Unit Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problems with the Golf 3 (Variant) Transmission, Chassis, Body & Interior
No new posts Airbag Fehler Bora Variant Erfahrungsbericht **Problem:*... On-Board Diagnostics (OBD)
No new posts Golf 6 Variant: Heated Steering Wheel Transmission, Chassis, Body & Interior
No new posts ASD AFN Golf Variant: What do you think? Diesel Engine Technology
