TDCI ruckelt manchmal bei Volllastbeschl.
golfschrauber1981
Post30-01-2005, 20:02    Subject: Quote
How about reading the error codes?
Chip specifications? More power/torque?
Could the clutch be slipping?
It could also be due to the chip!
Translated on 08-10-2026, 3:34.
golfschrauber1981
Post30-01-2005, 20:16    Subject: Quote
coupling is definitely good
It has nothing to do with being good or bad; it might simply not be powerful enough to handle the torque.
What is the original torque output of the engine?
Translated on 08-10-2026, 3:36.
Bee
Post30-01-2005, 21:07    Subject: Quote
ruckelt es nur einmal, oder immer wieder kurz nacheinander, so, als ob der Motor Aussetzer hätte? What is the speed?
Check the fuel supply!
'Micha'
Post30-01-2005, 21:37    Subject: Quote
Hi id&t,
How many kilometers has the diesel filter been in use?
Translated on 08-10-2026, 3:38.
Bee
Post31-01-2005, 10:26    Subject: Quote
@id&t: I kind of recognize the problem. Back then, it was a diesel supply issue. Possible causes for you: diesel filter, fuel pump (if you have one, you have a common rail, if I'm interpreting 'TDCI' correctly), or some kind of leak.
'Micha'
Bee
Post31-01-2005, 18:45    Subject: Quote
There are probably many possible explanations: for example, a vacuum might be forming somewhere that dissipates when you release the gas pedal; something might be stuck in the line and change its position when you release the gas pedal, etc. But: all of this is speculation. I would check the fuel supply and eliminate any anomalies.
If the problem still persists at that point, then we can consider further options.
'Micha'
Translated on 08-10-2026, 3:40.
No new posts Ford Focus 1.6 TDCi - Error code P1181 General Tips
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Causes of the shaking, Engine is shaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AAT: Rough idling, jerking, and occasional misfires Diesel Engine Technology
No new posts Ford Mondeo: Shaking & White/Blue Smoke - Causes &... Diesel Engine Technology
No new posts OBD2 for TDCi On-Board Diagnostics (OBD)
No new posts Central locking sometimes malfunctions. Diesel Engine Technology
