weku wrote: |
What is the purpose of the speed signal in the mass flow controller?
What do you understand by "menngenregler"?
If you're thinking about working with a solenoid valve for fuel injection, I strongly advise you to get the Bosch book on DI (direct injection) systems and go through it page by page.
Between the quantity interlocking and the gas wind tightness signal, there are still a few other things...
Quote: |
Actually, the amount of fuel injected should only depend on the engine speed.
The amount of fuel injected in a TDI engine is not linearly dependent on the engine speed. The load condition is also taken into account, and unfortunately, this cannot be achieved without a speed signal.
