Find the AAT, duty cycle, E-begin in the individual measurements?
Frank__
Post12-11-2004, 0:34    Subject: Find the AAT, duty cycle, E-begin in the individual measurements? Quote
AAT with first class honors. Version only displays measurement block 00.
That means, for example, in 4-4 mode, I can't see the duty cycle for the start of injection.
Can the duty cycle be seen in the 'individual measurement value,' and if so, what value is it?
What value would 100% represent, and what value would 0% represent?
Thank you for the answers.
Frank.
wolfi_b
Post12-11-2004, 7:17    Subject: Find the AAT, duty cycle, E-begin in the individual measurements? Quote
Look here:
[url][/url]http://www.dieselschrauber.de/Solldaten_5_Zylinder_VE.html{MARKER}
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Frank__
Post12-11-2004, 13:01    Subject: You misunderstood me! Quote
Of course, I know this data page!
but
'AAT with first class degree.' 'The display only shows measurement block 00.'
I think I might be able to find the sampling rate under the individual measurement values.
wolfi_b
Post12-11-2004, 14:02    Subject: Find the AAT, duty cycle, E-begin in the individual measurements? Quote
I have one of the first 1Z models, so it's the same situation as you have.
Can you see the duty cycle anywhere? I can't!
You can connect a voltmeter, and then you'll see them!
1993 Audi 80 B4 1Z
Frank__
Post13-11-2004, 2:11    Subject: I'm talking about individual measurements!!! Quote
Looking at the individual data points, you can see a large number of channels. These channels are not documented, but they likely represent data flows within the system. Ideally, there should also be information about the duty cycles available there.
No new posts Finding an OT with a multimeter. Diesel Engine Technology
No new posts Where can I find the coolant temperature sensor G62? Diesel Engine Technology
No new posts Drive Shaft Joint: Not Found? Find It Here! Transmission, Chassis, Body & Interior
No new posts I can't find it... Diesel Engine Technology
