Log file analysis: LMM (Lambda Multi Management), boost pressure, and error entries
x world one
Post10-11-2004, 10:33    Subject: Log file analysis: LMM (Lambda Multi Management), boost pressure, and error entries Quote
I need some help analyzing two log files. I created them because I believe my 1Z engine isn't delivering its full performance. Especially in the lower RPM range, it seems extremely weak.
That's why I created two log files.
Group 003+008+004 Idle
Group 003+008+011 with DZT.
I also had an error entry in the memory.
Code 01117
The vehicle's fuel consumption figures are acceptable (see signature), but the elasticity and power output are poor.
It would be great if someone could take a look at the logs.
Spritmonitor
Translated on 10-07-2026, 11:55.
Post10-11-2004, 11:04    Subject: Log file analysis: LMM (Lambda Multi Management), boost pressure, and error entries Quote
So, I can't identify any clear indications of the problem you're experiencing.
Please generate another DZR log with values 004 and 008, and compare the target (scheduled) and actual DZR times.
Translated on 10-07-2026, 11:56.
x world one
Post10-11-2004, 11:34    Subject: Log file analysis: LMM (Lambda Multi Management), boost pressure, and error entries Quote
Thanks, Ulf. I'll run another log today.
The only thing that seems a bit strange to me is the boost pressure curve.
I think the turbocharger is building boost too slowly. The vehicle seems to behave similarly in this weather (2-7°C) as it does in summer temperatures, meaning it subjectively has slightly less power; subjectively, it has "decent" power in the range of 10-15°C.
Or I might have to accept the fact that my old 1Z engine had a significant amount of inherent variation, leading to higher readings.
The only error message that is still unclear to me is the one related to the Lima clamp. As far as I know, this error indicates a safety shutdown due to overload of the alternator (Lima).
Spritmonitor
Translated on 10-07-2026, 11:58.
Post10-11-2004, 13:23    Subject: Log file analysis: LMM (Lambda Multi Management), boost pressure, and error entries Quote
x world one wrote:
Thank you, Ulf. I will run another log today.
Ich finde, dass der Ladedruck zu langsam aufgebaut wird.
I don't think so.
Starting from full throttle (driver's desired value = 44 mg), the actual value practically does not lag behind the target value.
Translated on 10-07-2026, 11:59.
Post10-11-2004, 14:28    Subject: Log file analysis: LMM (Lambda Multi Management), boost pressure, and error entries Quote
Oops.
I'm not able to do anything anymore... sorry icon_confused.gif.
You can ignore that error; I have it too because of something internal, and I just delete it when I get a chance.
Translated on 10-07-2026, 12:00.
Post10-11-2004, 15:27    Subject: Log file analysis: LMM (Lambda Multi Management), boost pressure, and error entries Quote
Okay, based on the log data you posted, it shows a really well-regulated boost pressure profile.
Always try to stay on track.
"Even the LMM values look better than mine."
A decrease of just 10 cents in the interest rate makes a noticeable difference on a loan, making it significantly more affordable.
Where 2 mg/R already looks almost perfectly tuned at 903 U/min icon_smile.gif.
The injection start control in the LL also seems to be fine.
I can't find anything either - except for a surprisingly low fuel consumption.
Translated on 10-07-2026, 12:01.
No new posts Document A3, 8 liters, up to 2000, Error entry in the air... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Hard landing - no error entry - troubleshooting? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Unlikely Signal 16485-LMM: Log File Analysis Needed On-Board Diagnostics (OBD)
No new posts 1 x Log file for engine control module (ECM) code MWB0 an... Upload
No new posts Log File Analysis: Insights & Optimization On-Board Diagnostics (OBD)
No new posts Log Analysis: Audi A6 2.5 BDG (3-8-11) On-Board Diagnostics (OBD)
