VW PD Timing Belt: Brown Wear - Is It Normal?
onclebenz
Karma: +0 / -2   Thank you, like it!
1987 Mercedes-Benz SL Class
Post22-10-2004, 11:39    Subject: VW PD Timing Belt: Brown Wear - Is It Normal? Quote
Hello!
"When I changed the timing belt, I noticed a lot of brown debris. Is that normal?"
And where does the dust come from?
Is it the timing belt that's failing?
http://gallery.t4forum.de/data/media/9/lupoklein_2.jpg
Translated on 28-09-2026, 10:39.
delvos
Post22-10-2004, 12:46    Subject: VW PD Timing Belt: Brown Wear - Is It Normal? Quote
/viewtopic.php?t=3857&highlight=reibrost
With "Search," it's easy to find icon_biggrin.gif.
delvos
onclebenz
Post22-10-2004, 15:03    Subject: VW PD Timing Belt: Brown Wear - Is It Normal? Quote
Yes, I've already read something about that.
But since I've already uploaded the picture, I would appreciate a review.
Best regards.
ONCLEBENZ
Translated on 28-09-2026, 10:40.
Michael II
Post22-10-2004, 16:33    Subject: VW PD Timing Belt: Brown Wear - Is It Normal? Quote
It looks the same on my AJM.
Tschüss
Michael II
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post22-10-2004, 17:23    Subject: VW PD Timing Belt: Brown Wear - Is It Normal? Quote
Yes, that's normal!
B.Eng (FH) u. KFZ Meister
Translated on 28-09-2026, 10:41.
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post22-10-2004, 18:07    Subject: VW PD Timing Belt: Brown Wear - Is It Normal? Quote
Hi!
It looks the same for me too. But on a different note: Is your hydraulic tensioner leaking, or is there just some oil "dribbling" out of it?
Dirk.
onclebenz
Post23-10-2004, 11:22    Subject: VW PD Timing Belt: Brown Wear - Is It Normal? Quote
"Good question, I'm not sure. Is a slight oil leak normal?"
brezelmann01
Post23-10-2004, 20:56    Subject: VW PD Timing Belt: Brown Wear - Is It Normal? Quote
Well, it should actually be sealed. It's not connected to the engine oil circuit. And if it constantly leaks oil, its damping effect will definitely decrease eventually...
Polo2004
Post24-10-2004, 10:40    Subject: VW PD Timing Belt: Brown Wear - Is It Normal? Quote
Okay, the oil leak is not normal. This could lead to the timing belt not being properly tensioned at some point. A small tip: if the timing belt is still in use, check the water pump bearing for play and check for leaks.
Best regards, Christian.
Translated on 28-09-2026, 10:42.
onclebenz
Post14-11-2004, 12:08    Subject: VW PD Timing Belt: Brown Wear - Is It Normal? Quote
Okay, I didn't replace the water pump; it was still working perfectly.
I also left the span element in place, but I will keep an eye on it.
Possibly, the oil is coming from somewhere else, because the connection from the crankshaft ventilation to the turbocharger was leaking, and the area underneath was quite oily.
I used a hose clamp to fix it, and now it's sealed.
Generally speaking, replacing the timing belt wasn't a particularly difficult task.
It still took me quite a while.
You just don't want to do anything wrong.
Thank you for the tips!
Translated on 28-09-2026, 10:43.
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Filter Debris AXR 1.9L TDI-PD Diesel Engine Technology
No new posts LLT normal ? Upload
No new posts Oil in Coolant: Is it Normal? Diesel Engine Technology
No new posts Only 8 volts on the N75, is that normal??? Diesel Engine Technology
