The outside temperature sensor is showing a reading that is 5 degrees too low
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
tobi999
Post23-11-2004, 13:18    Subject: The outside temperature sensor is showing a reading that is 5 degrees too low Quote
Dear A6 experts,
My outdoor temperature display has recently been showing a reading that is consistently about 5 degrees too low. Regardless of whether...
It's either cold or warm outside. Can this be adjusted, or do I need a new sensor?
to be installed. 'Regarding the inquiry about Audi, well, that would probably require a new...'
'Let's try it,' but 'we don't have something like that here.'
Thank you for your help.
No new posts Doku A2 8Z0 Mj 2002, Bordcomp. zeigt nur Reichweite Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG 1.8L R4/5V 125hp (92kW) Naturally Aspirated Gasoline ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Outside temperature sensor Electrical Systems, Vehicle Electronics, Multimedia
No new posts Lüfter erst bei ~ 97,8 Grad - normal? Diesel Engine Technology
No new posts Einspritzung 17 Grad v. OT.....kann das gutgehen....? Diesel Engine Technology
No new posts JMA lässt sich bei -13 Grad besser schalten ?! Diesel Engine Technology
