The outside temperature sensor is showing a reading that is 5 degrees too low
Search
Automotive Technical Articles
Bookmarks
Links
Garage
Books / Tools
FAQ, Legal Notice & Privacy
RSS Feed
Register
Login
DE
EN
IT
New Topic
Reply
Dieselschrauber - Index
View previous topic
View next topic
Author
Message
tobi999
23-11-2004, 13:18
Subject: The outside temperature sensor is showing a reading that is 5 degrees too low
Quote
Dear A6 experts,
My outdoor temperature display has recently been showing a reading that is consistently about 5 degrees too low. Regardless of whether...
It's either cold or warm outside. Can this be adjusted, or do I need a new sensor?
to be installed. 'Regarding the inquiry about Audi, well, that would probably require a new...'
'Let's try it,' but 'we don't have something like that here.'
Thank you for your help.
New Topic
Reply
View previous topic
View next topic
Topic
Forum
Doku A2 8Z0 Mj 2002, Bordcomp. zeigt nur Reichweite
VAG 1.8l R4/5V 125PS (92kW) Saug-Benziner, wenig Drehmoment
Außentemperaturfühler
Electrical Systems, Vehicle Electronics, Multimedia
Lüfter erst bei ~ 97,8 Grad - normal?
Diesel Engine Technology
Einspritzung 17 Grad v. OT.....kann das gutgehen....?
JMA lässt sich bei -13 Grad besser schalten ?!
Select a forum
Diesel Motorentechnik
Benziner Motorentechnik
On-Board-Diagnose (OBD)
Dieselschrauber Bar
Allgemeine Tipps
KFZ-Technik-Artikel
Fehlersuche & Anleitungen
Technische Daten
Fachartikel
Weblogs, persönliche Webseiten
Community Blogs, persönline Webseiten
KFZ-Technik Quiz und Halden
Quiz
Upload
Schrotthalde
You
cannot
Foren- und Portal-Software: V7.1 © 2003 - 2026 Kaufmann Automotive GmbH,
Embedded Softwareentwicklung
Shop für VCDS und OBD-Diagnosegeräte
. Parse time: 0.079s
