Clutch Input Shaft Diameter 1Z/AFN
Zibi
Post19-11-2004, 0:15    Subject: Clutch Input Shaft Diameter 1Z/AFN Quote
I'm relatively new here and I'm also very enthusiastic about reading everything.
Right now, I'm converting a T3 to use TDI technology and simultaneously installing a Renault transmission. I need to know if the AFN and 1Z engines have the same spline count for the input shaft, or if I might need an adapter sleeve. The input shaft of the transmission is 23mm thick. Does anyone know what the diameter of the hole in the clutch disc of the 1Z is?
It's poorly phrased, but hopefully understandable.
'Hello,'
sebastian
Translated on 24-07-2026, 0:16.
Wolfgang, syncro16
Post29-11-2004, 12:43    Subject: Clutch Input Shaft Diameter 1Z/AFN Quote
Hello Sebastian,
Do you know Maciek's website?
http://www.stud.uni-saarland.de/~mamr0001/un1-getriebe.html
That's exactly how it's described.
The type of splining on the clutch depends on which gearbox it was connected to. For example, clutches for the Sharan have a different splining; however, often it is sufficient to simply replace the clutch disc.
Hello.
Wolfgang.
Translated on 24-07-2026, 0:18.
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Squeal: A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Clutch Slipping - 81kW Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Flywheel: Outer Diameter? Diesel Engine Technology
No new posts Valve Hole Diameter: Find Your Rim Size Here Transmission, Chassis, Body & Interior
No new posts Coupling Diesel Engine Technology
No new posts A4 8K SAC Clutch: Replacement & Upgrade Transmission, Chassis, Body & Interior
